Kyosho V-ONE RRR Evo
#3211
You can download the later manuals (Evo 2, Evo 2 WCE and the Shimo Edition) from Kyosho Americas web site. If I'm not mistaken, from the Evo 2 onward, the rear pivot balls are 2 mm further outward and the camber links are made longer with one short and one longer ball cup instead of two short ball cups, (the previous RRR's used +2 mm offset rear wheels to get the rear track width out to 200 mm. I'd consult an Evo 2 or Shimo manual to better make sense of all the possible different rear suspension combinations.
HTH
HTH
#3213
They have Titanium parts for these Cars as well........CHEAP!
#3214
IF 3 Racing parts are acceptable, you can still find aluminum option parts for the RRR at a place called www.asiatees.com
#3224
Im back lol im still running this car. I have found most of the parts still between Ashford and Amain.
Question is im running the front gear diff and cant find part numbers on it or part numbers for the components. Are the outdrives the same front and rear? The diff cases are different of course. I cant find anything on it in the manual under parts or options. Thanks for the help.
#3225
I'm still running a Shimo Edition and no, the front out drives are not the same. You'll need the VZ218's for the front diff. I'd also add Titanium cross pins for the spider gears, to both diffs VZW211 and Titanium Pivot Balls VZW023V-8 along with a Lite Weight body and a LiFe Rx pack will bring the Cars weight down to about 1650 grams!
I also use the optional wide front bumper VZ244 and the APP02-2 Brake Pads w/ball point pen springs shortened and installed between the pads so they don't drag.
Yeah I know, more info than you asked for But, the Cars "A Tank" and so easy to drive on a parking lot Track.
