Kyosho V-ONE RRR Evo
#182
Can Fax one
Originally Posted by fritzD
I just got my RRR evo. THe set-up sheet is in Japanese!!! DAMN!!! The pdf set-up sheet offered in Kyosho's site is also in Japanese. Is there an English set-up sheet available somewhere??
I can fax one.....Don't have available scanner. If so, email your fax # to [email protected]
#183
Front Uni's?
Does anyone know the part number for Front Universals that will fit the RRR Evo???
#186
Thanks for fast reply guys, much appreciated.
So, will the VZW219 work with the front one-way as well as the diff?
Thanks again.
Thanks again.
#187
does anyone know what brake disc (besides stock) will fit the evo?
i know the kfactory disc won't fit any i don't think the kawahara one will either....
#189
Originally Posted by RMF-888
nid help
what is the best futaba servo that i can use in steering and throtle?
#190
Originally Posted by jag
I use the 9451 for both.
#191
#192
Is anyone tested & compare the performance & handling compare to V1RRR?
#193
not yet but i can tell you that all of the issues have been sorted out with the evo.
I still can't get over how smooth the shocks are!!!!
i have never felt shocks as smooth as the ones on the evo!
definatley worth getting this kit!
#194
Is the shock o-ring not the same as the old one?
As we know that the CG has been increase a bit due to the throttle servo (stand up) compare to laydown. Not sure it will affect the cornering performance...but I still trust Kyosho.... don't you people agree?
Just hope that someone prove it and update us here.
#195
i still believe that the servo position will not contribute much to the change in CG. it's very minor shift of weight. compare with what's sitting at the other side of the servo, which is the engine.
reminds me of the old days when OS LD was released for the kyosho superten. That's what you called lowering CG.
nowadays it's just gimmicks perhaps? nonetheless i trust Kyosho can win with this car.
