Ceramic Thrust Bearings
#31
As for wear: Remember, Oilite is not just sintered brass. It's sintered brass that is stuck in a vacuum chamber to remove all the air from the gaps between the brass granules, then dunked in oil so the oil soaks into the gaps and stays there. That extra little bit of oil significantly increases the bushing's longevity, since brass is already a self-polishing alloy. Oilite was originally invented as a bushing material for coolant pumps in automobiles, which run for YEARS with no maintenance whatsoever.
#32
Oilite could be a thing to look at. I have found some companies that sells plain bars and also thrust washers.
A bushung handles much different and lower forces than a thrust washer, as mentioned I had made washers from a bearing bronze and they were gone in a moment. They were squeezed.
#33
it really is the best tool I own its such a pain with the caliper u have to recheck it like 3 times that tool is the shit@@ and u right I could never give up racing even without a track ill race around the sewer cap in the street!! lol
#34
Hey Ralph can you take a picture of the tool you have or made ? how much did it cost you ?
#35
#36
#37
Blowing thrust bearings is more about too much endplay.
#38
Normally thrust bearings fail becaus of too much end play. Once you have the clutch gap correct or close (normally between 0,5 and 0,7mm) just shim out the end play with shims between flywheel nut and inner bearing untill you have the least amount of end play without the bell feeling tight on rotation. In my opinion anything over 0,1 is too much.
#39
#40
#41
