Ceramic Thrust Bearings
Anyone use them and if so what is your take on them are the worth getting ?
As with every discussion: is ceramics better?
If it is for the clutch I do not even use a bearing... When does the thrustbearing actually works. Only on the moment the clutch engages. With Idle it runs free due the play and on high revs it is standing still. Does it need a performance or a light resistance? No, because when the cluch is engaging there is already a huge slip withthe clutch shoe and bell... So Because the thrust bearing can fail in a race I eliminate the chance on a failure to zero by replacing the ring with the balls with a brass 10x5 washer with some greese. http://www.euronet.nl/users/tooms/koppeling/messing.jpg See it as a ball less bearing |
Originally Posted by Roelof
(Post 15082292)
Not needed here. Taking the extra chance of fractures in this application not worth it. A thin film of high quality grease is enough. The more grease you add, the more dirt sticks around. Use it sparingly.
What happeneds for the symptoms when a thrust bearing fails ?
When the thrust bearing fails you get:
- changing ways of how the clutch engages, from low rpm to many slip. - when all the balls are out the clutch will stop working |
What kind of high quality grease do I use with I run without the thrust bearing ?
The same grease, the white which came with the Mugen kit. It is a bearing grease of which I also did get a large tube.
(Post 15083166)
I use Lucas oil red and tacky.
(Post 15082292)
If it is for the clutch I do not even use a bearing... When does the thrustbearing actually works. Only on the moment the clutch engages. With Idle it runs free due the play and on high revs it is standing still. Does it need a performance or a light resistance? No, because when the cluch is engaging there is already a huge slip withthe clutch shoe and bell... So Because the thrust bearing can fail in a race I eliminate the chance on a failure to zero by replacing the ring with the balls with a brass 10x5 washer with some greese. http://www.euronet.nl/users/tooms/koppeling/messing.jpg See it as a ball less bearing Pass you soon... |
Originally Posted by BigC2007
(Post 15083119)
I use ceramic bearings in my clutches because I can run them without lubrication to keep the inside of the clutch from being contaminated. I have ceramic clutch bearings several years old that still work fine, despite being run without lubrication from the moment I installed them.
If you want to use a brass washer instead of a thrust bearing in a Centax clutch, you should use an Oilite bushing instead, because it will supply its own lubrication as it wears-down. |
The brass bushing idea is pretty clever if you polish all three plates and the bolt to the point where there would be almost no friction between them with bushing lube or bestline powertrain lube. You can thereby eliminate grease totally, and avoid the mess... I have used the master formula polish on brass bushings before and they can get super smooth enough to do away with balls for good....
Originally Posted by fyrstormer
(Post 15084545)
Originally Posted by bertrandsv87
(Post 15084549)
