M2C SHOCK PISTONS AND BLEEDER CAPS!!
#16
Location: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
I ran these caps last weekend at Thunder Alley for the Top Notch series and they were nice. The caps really help you build a dead shock. I'm also running the 5 hole brass pistons with 650/500 but as the weather cools in California ill be testing with different weights.
#17
Which car you use?
#18
It was 80- 90deg. the day we ran but its cooling down to 75-80 and I have a mbx7r.
#20
#21
I like those Pistons! Gonna try them out on my MBX7R
#22
Where can I get these caps m2c2515 KYOSHO 16MM ZRS(ZERO REBOUND SYSTEM) SHOCK CAPS?
Thank you
Thank you
#24
Thank you
#25
6 x 1.3mm oring pistons require very light oil , thats why i made 6 x 1.5 and 8 x 1.4 , thin oils do not make for a good feeling shock . I played and played and played with oring pistons . They have great benefits when you find the right fluid weight to create a proper feeling fluid transfer in shock that makes the car just float and handle so good .
6 x 1.3 i used
20-27.5w losi rear
30-35w losi front
Reaaaaaaally light oils
I recommend drilling em larger
Multiply # of holes and size , 6 x 1.3 =7.8 , 8 x 1.2 = 9.6 , 5 x 1.5 = 7.5 , etc . , simple method ï
The oring pistons are awesome , they react heavily to small changes in fluid viscosity as all the oil is going through the transfer holes and not bypassing around the piston .
KYOSHO FTW
6 x 1.3 i used
20-27.5w losi rear
30-35w losi front
KYOSHO FTW
#26
6 x 1.3 i used
20-27.5w losi rear
30-35w losi front
KYOSHO FTW
6 x 1.3 i used
20-27.5w losi rear
30-35w losi front
KYOSHO FTW
now to my question, Im running for Serpent this season, they run a 5-hole 1.5mm and 1.6mm rear.. with 475 front 450 rear....does this translate, but this is what the whole teams running currently, I have some VRP Game-changers, Brian sent too me, theres NO WAY they don't work, lol,. just not sure on the setup, also do, Kyosho springs work On serpent shocks? they should 16.. right? big bore?
I do Believe the pistons are interchangeable, I sent Brian, the stock pistons from E0Buggy that just landed here.....Any idea where to go w/game-changers, to acquire this "plush" ride.....I know your a fast dude, glad to see your still at it, I took a hiatus...
As for springs I have the kit purples, which are 4.5 front and 3.5lbs rear, also have Red fronts 4.0 and Blue rears 3.4.....
and your method is simple/and proven, if your going to open holes on pistons, which I hope guys have a hold on that by now, but would be nice to have a desired Pack, and say a weight to aim for, from manufactures, this day and age, like loamy track, use your math for exp..7.2 front and 8.6 rear, and just leaves the "feel" up to the racers, amount of holes, size oil, I totally agree with you, I used to run my Kanai with 40 plus weights, seems there going down and down, to 2wd electric oils??>
#27
I use flash and m2cracing cup point for my mbx8 it s fantastic
#28
that applies for kyosho, and agreed Mitch Is top Notch, I miss out long conversations about this and that, I used to send him parts to make measurements, did lots of testing YEARS ago on his clutch systems, man I ran every spring shoes density etc,
i bleed kyosho , always have always will
look at teknos stuff , 3x2.1 and bigger , it works
#30
So just bought the 16mm shock pistons, m2c9727
Any recommendations for clay low grip setting to start with? Do I use white piston in the front, black in the back? I guess 400CST to start with and work from there...
