Hotbodies D817 Nitro thread
#331
Any one know if the JConcepts Illuzion Finnisher Body for the Xray XB9 Buggy.will fit the D817
#332
Any used D817 for sale?
#334
You could go long link on rear, you could drop down 1 hole on camber link at tower , lighter rear swaybar, more rear toe, add .5 of toe at rear knuckle, you could drop down to the lower holes at rear knuckle......... There's more
#338
No I've always gained traction by going lower on the tower..........upper holes makes everything move faster. Front and rear. Imagine how much better your car will be now. Lol. Been wrong for awhile!
#339
Two questions
How does a lower Rear tower help?
How do you get .5 degree on rear hub? Blocks just move it up and down.
#340
Your right, but you can flip the pill on the front side of the hub or maybe it's the rear. But it will give you .5 more toe. Something a lot of HB guys don't always tell you
#342
You would only flip one pill. You'll notice they are triangle shaped so point the front one in-board and the rear one outboard.
#343
#344
Thanks guys. Just checked our two buggy's and and I had set them up exactly opposite from one another with out realizing it. They handle quite different and I couldn't figure out why. Now I know.
#345
I use my diff oils to help square the buugy up exiting corners under throttle too.
Here's the Drake explaing roll center and how higher on tower gives you grip.
https://m.youtube.com/watch?v=zG9_4u...ature=youtu.be
