Hotbodies D817 Nitro thread
#707
What parts should I have on hand for ebuggy and nitro v2s
#708
I answered you on Fbook already but yea don’t need much. I’ve been driving it for months haven’t broke anything. Drive line pins are thing that wears faster so maybe get spare center drive line or some extra pins to replace them.
Car is amazing drives better then anything I’ve driven.
#709
Hey guys just picked up a D817 v2 from a friend and I can’t seem to get the rear ride height higher then 27mm. It’s on blue springs with 40wt oil and 5x1.5 pistons. The collars are maxed out to the point where if I turn it anymore the collar will be off the thread and floating on the shock body. Everything has checked out to be perfect on my rebuild. Shocks are the right length and everything is where it should be, so I have no idea what’s wrong. All I wanted to achieve was one of David Ronnefalk’s setups set at 28mm rear height.
Any help would be great!
#710
Does the rear suspension extend when you Lift it up?
#711
do you have small tower on it?
maybe you don’t have the longer shock shaft ends on ?
#713
thanks for help guys!
