Serpent SRX-8 Nitro buggy
#961
Guys that were having that problem ended up glueing the inserts into place, rather than using screws. Also with colder temps coming, you may not need such a stiff arm.
#962
#963
Looking at buying a used SRX8 evo from a local racer. I mainly am looking to buy for practice and running at the track, are the Pro upgrades more performance oriented or are their items I should look into for durability and ease of driving?
#964
The pro parts are mostly upgrades. The caster blocks and spindles are for performance, but I do t think it's anything noticable for some practice days.
#966
Mounting the engine and getting the linkages setup for the motor. Is it normal to have the carb at such an angle? It’s the only way I could get it to fit and have the carb I line with the servo arm.
#967
Yup that's how you gotta do it. I my thing I see to fix may be the sub trim to where the brake side of the horn is in line with the servo. Also could be the angle of there photo
#968
#969
#970
#971
My steering horn is aluminum. I'll wait to see what breaks first and then replace parts as I go. This is my first 1/8th scale and I'll just be practicing for the remainder of the warmer fall days we have as the local race club is done with outdoor racing till next season.
#972
Any recommendations on droop settings? I noticed my rear left and right droop is not the same. Just looking for a good starting point.
#973
The standard set up is right where we've been. 106mm front 128 rear. Measure with calipers from center to center on the screws with chassis on a car stand.
#974
I know the RTR 811b Can be upgraded to pro kit. But I’m confused as to whether they meant the 811 pro kit from a few years ago or if it carries onto the current srx-8/evo/pro. Basically can I use the info from this thread to upgrade the RTR version?
#975
Super Moderator
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
the 811 does not carry to the srx8 car. a few parts but not enough to justify..
