Serpent SRX-8 Nitro buggy
#256
I was not even able to get hydro lock. The shock would have no rebound no matter which way I tried. I was trying to get 25%. I built using one of tessman older shock video. Just ended up building following drakes video. Anyway if someone has a video showing rebound on these shocks I would love to watch it. As I was not able to get any.
0 rebound means you wont get any shaft out when fully push in, is this clarify your issue?
#259
old cobra 811 option reusable
#261
#262
Diffs?
Are the diff gears like the "old" 811? And not the V2? Default setup shows 7/7/5 for the SRX8. The 811 2.2 default setup is 12/12/6 this was with the V2 gears.
I'm asking because I never ran the V2 gears in the 811 so I never had to buy all the 10K+ diff oil. I assumed I would need to with the SRX8 but maybe not?
Newman shows he ran 20k in Las Vegas...... but other team drivers are staying more in the 7k-10k range....
So which is it?
5K Old 811 gears | Was 10K in new 811 V2 gears | SRX8 Gears Back to 5K???
So which is it?
#263
Do you guys know if these- https://www.amainhobbies.com/serpent...600660/p240026
will work with a 2.2? it says they're compatible with a 2.1 wat about a 2.2? meaning V2 hubs and steering knuckles would be 2.2 right? so would these aluminum axles work?
#264
So which is it?
So which is it?
Paco
#265
Jupa Creations/ CRD has finally released the production version of the SKY-RC switch cover plate for the Serpent SRX8. The switch cover plate replaces the kit version with the holes for the mechanical switch. The design is made so there are no holes and the top is flat. The LED's for indentification of the POWER and LIPO are visible through the plate when activated.
You can disassemble the original SKY-RC switch Model:SK-600054 by removing the four small screws at the back. Remove the bottom and take the electronic switch and place it in the SRX8 switch cover plate. Place the clamp and reuse three of the small screws to secure the clamp. Mount the SRX8 switch plate with the two original screws that come with the kit switch plate on the radiobox.
When you place your finger on the top of the switch cover plate you can clearly feel the switch moment.
For those with interest please send me an email for price and shipping.
Paco Raap
PS. Parts are 3D printed and not molded. Inpurities in the surface might be visible.
Jupa Creations/ Custom Racing Decal
Paco Raap
#266
Did you guys use servo spacers with the Cobra or Srx8 particularly with hitec servos?
#267
Do you have an opinion on my question? 811 old diff gears vs 811 V2 diff gears vs SRX8 gears and oil weight?
#268
SRX8 kit comes with 7000-5000 as standard.
http://www.serpent.com/product/600727/spares/list/
No idea what is inside the V1 and V2 diffs.
Paco
#269
