Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1906
Hi guys.
Anybody knows how to get the bottom motor mount screws - 4x10 flanged cap head (if431), without having to also buy the mount plates ??
And i cant find anything like it. I like that it fits a 3mm hex. And there is not enough room to use a normal cap head with a shim.
Hope someone can help me out here.
#1907
Was I the only 1 that had to Dremel the openings for the motor mounts , to get the mesh right on the samurai v2
#1909
I have an announcement to make, I now have a FB page where I will post videos, tutorials and guides to help you guys become setup gurus. Check https://www.facebook.com/Hephaestus-...6808876003561/.
#1910
#1911
Setup
Afer looking and downloading tons of jareds and elliots setups ive noticed they both run tki3 b plate and front nuckles aswelk as in most they run 16 degree cast blocks???
#1913
just got the kyosho aeration caps. amain website says to use a heavier oil with the caps but the instructions don't mention it.
just wondering what the consensus is of those who have used the aeration caps. did you use a heavier oil or use what you normally do. atm i'm using AE 45f 35r. tia
#1914
I have used the aeration caps for some time now and I needed to go up in thickness compared to the stock caps just to have the same feel. I think that Y. Kanai explain it well enough in his youtube video. According to him you need to go up in thickness and that is also my findings. He mention 100-150cst higher than you had with the stock caps but that just get you in the ballpark but it is a good guideline to follow.
For me the aeration caps are better and gives me a easier car but the stock caps have their place as well.
#1915
T-work's options
Have anyone tried T-work's option parts in carbon fibre for tki4? Radio plate, center diff top plate, transponder holder plate, upper plate and switch plate.
I wonder if these parts are as durable as the stock parts and if they changes the performance of the car in any way.
Any feedback would be good!
#1917
#1918
I went up 100cst compared to my stock setup and it was good. I settled with only 50cst heavier oil due to outside temp and the car was perfect for my track, what I try to say is that you need to try for yourself.
#1919
Orange springs??
When running orange springs do i leave the oils the same or bring them up? After running them after a day a practice the rear of my car was put during corners and was so easy to drive but was land hard after jumps
#1920
thanks. was just curious about what you used. will start with ~100 heavier and go from there.
