Kyosho Inferno MP9 TKI4 1/8 Buggy Kit
#1936
Hi, im new to the TKI4 and slowly settling in after trying to get the Xray to work on dirt for too long.
Anyway, I raced a club race this week-end and in the last 3rd of the race I suddenly got into the groove and nailed 6 consecutive fast laps with about 0.1% consistency. I normally get the fastest laps in first 3rd of a race but didn’t think much of it.
When going through the car after the race I noticed that 2 of the forward most screws attaching the radio tray to the chassis were lost, and the middle one 50% unscrewed. In hindsight my theory is that the added flex was good for me/my setup/the track etc. Strangely I nailed the largest jump MUCH better and I was way more consistent in the tight corners (not so strange). The bump handling and high speed sections felt the same.
Any ideas on how to achieve more flex or a similar feel / behavior in the car with all the radio tray screws firmly secured?
#1937
No worries. I do run the front upper arms high (9 dot up and dot up) in order to achieve a lower roll center in the front.
#1940
Hello guys,
I am really interested to know if I can turn a Kyosho Inferno MP9 TKI2 to TKI3 and further to TKI4 (as long as a TKI3 can be upgraded into a TKI4).
If something like this is possible, could someone show me a list of the needed parts for the upgrade?
Thanks in advance, that's a really big trouble for me.
#1941
Hello guys,
#1942
I've just installed the 17.5* castor blocks to try and I noticed that I wasn't getting the droop I was before (103). Upon investigation I found that the caster blocks are hitting on the arm because they are laid back more. Limiting droop. I can only get 102. Thinking I might just get the dremel out and make some clearance.
Just wondering if anyone else has come across this problem. tia
#1944
I'm also looking closely at your setup 30Tooth. Working my way up to it. Got the aeration caps installed and ready to try next meeting also (2 and a half week wait dammit).
#1945
No problem, I didn't tried that much droop and have reports of issues above 102mm.
For those having steering problems I remembered yet another thing. The TKI4 uses same pistons front and rear,which is wrong, the damping is all out of whack and most if not all cars have more rear damping than front, making the rear even more supported than the front.
#1946
Just have a look at the setup sheets from any of Tebo, King, et al from their race wins in the past 3-4 years and almost invariably, you'll find they have been using the 1.3x8 hole white pistons in both front and rear shocks. Again, obviously they use different oil viscosity at each end but there's certainly no problem running the same pistons at both ends.
What exactly is the handling problem you're trying to sort out?
#1947
G'day mate, a couple points I want to address.
First is that I don't trust pros setups, I don't drive like them or think like them. I prefer the Physics approach. No hard feelings about tuning by feel.
I know first hand that using same shock piston setup front and rear is not good, there's a couple of reasons. The most important is that the rear shocks are mounted closer to the wheel than front shocks are, that changes leverage for both spring and damping. That way, the closer the shock is mounted to the wheel the more damping/spring it will offer to the wheel. Building on that one could think that shock oil takes care of the difference but truth is that it isn't enough nor provides the same progression as carefully calculated piston hole area. That's why you use close to same oil front and rear with the different shock piston hole diameter, it's because the damping at the wheel is very close and therefore balanced.
This stems from 1:1 shock tuning which for what I know uses same "oil" but changes piston hole and shim stack to achieve balanced damping.
Hope it helps mate.
Hope it helps mate.
#1948
Sup Guys! Long time reader, first time posting.
Has anyone ran the +2mm MS front end with the new emulsion style caps? If so, do you like it better then the shorter stuff? From what I see and hear the longer front shocks are not preferred. Looking to rebuild my rig after a long break and trying to decide which way to go and can only make 1 small parts order before my first race lmao. Thanks
#1949
Hope it helps mate.
Hope it helps mate.
#1950
