Team Durango DNX8 1/8th Nitro Buggy
#76
Hi there guys,
Hope you are enjoying your cars!
I'm driving the car already for a long time and also have tested many things since I'm a pilot run user.
And because of that, wanna share some tips we've found:
a) Remove the 2 large shims from the centre diff to help make the diff mesh free’er and more reliable.
b) The tank lid seal can be adjusted with the screw in the centre. The tighter the screw the LESS the tank will seal. Screw-off 1 or 2 turns just make it perfect.
c) For the front bumper not touch the inserts, also have removed the boss inside the front bumper
d) Also, glue the nut in the servo-saver
Car really works well as the base setup, but I found for easy driving that a thicker oil in the front diff might help. So, instead of 5k, 7k, 3k (front/center/rear) try 7k or 10k, 5k, 3k.
#77
Aside from letter "B", do these build tips directly translate to the DEX8 too? Mainly wondering about the center diff shims. Although I've had the DEX for a couple of days, I've only had a chance to look at all the pretty parts. Hoping to start putting them together tonight.
#78
#79
I know i should be running the stock set up and gauge my performance from there.
but i'm not...lol
Going to be running Imbue V2 8 hole pistons, Novarossi 13T vented clutch bell, Reds Quattro Clutch, & Kyosho light blue springs front and rear. I will start out trying 7-5-4 for the diffs.
since i'm in arizona and the weather is warmer here..
but i'm not...lol
#80
I've added your comments to post #2 on this thread. Thankyou!
I'll try and keep ahead of constructive realworld experiences with this car that people post here. Lets make this a great thread
If you want me to update post 1 or 2, please PM me, I'd be happy to add stuff.
Hoping to build mine this weekend
#81
Hi Guys, I have been running the car for a while now as i am also a pilot run user!
Carlos put up a lot of good tips/experiences with the car already.
I found while running the car that i preferred the durango blue shock o-rings the best for the smoothest shock action possible, the purple o-rings are also a good option that will last a little longer but wont be as smooth as the blue (Blue - TD330611 or Purple - TD330612), When i put the o-rings in the shocks i use some shock o-ring grease to make them even smoother.
When it comes to bleeding the shock i do this with the bladder in the cap and screw it on gently (when you have the amount of rebound set) to let the air and excess oil out! The best ways that i have found to run the caps is with the foam and with out the screw or my personal favourite is no foam and with the screw, but i would recommend trying both.
Another very useful setup option that i have found is the active caster, adding more active caster gives more off power and on power steering, i like to run 3 dots down!
Any questions feel free to ask!
Aaron
Aaron
#82
Aaron
Aaron
cool...
#83
Question about the rear toe in section of this setup help guide...
http://www.team-durango.com/pdf/setu...ips%20Card.pdf
The hinge pin hole is opposite the bar. So if the front bar is in and the rear bar out according to the chart, you should have 5 degrees of rear toe... BUT the holes would be actually out on the front and in on the rear in that scenario. Is the chart right or is it backwards (and should be referencing the hole position as opposed to the bar position)?
#84
#86
Hint & Tips
From crazyfonseca:
e) Car really works well as the base setup, but I found for easy driving that a thicker oil in the front diff might help. So, instead of 5k, 7k, 3k (front/center/rear) try 7k or 10k, 5k, 3k.
From crazyfonseca:
#88
more on power steering and makes the car feel easier to drive but you will lose of power steering.
I would recommend to take them out, they make the diff feel tighter after a few runs!
