Mugen MBX7R
#811
Yes
#812
After driving the 7r a bit now there is one thing much different than other buggies I've had. The car doesn't get nearly the lift off the jumps in my opinion. Anyone tried a progressive spring such as Kyosho light blues. I ask because I have a few sets of them. I believe they are softer than the stock springs on initial compression but stiffer when compressed. Curious to hear feedback of others who've tried them.
#814
Has anybody noticed the fuel tank clunk sits shorter than in the 7? I took the pick up out and put a tube 1/8' longer than what was in there. now it sits in the bottom pocket nice. but you have to be careful if you put new tubing thats a little too long it wont be able to flop upside down.
#815
Mine was also the same way. About a 1/8 longer is all that's needed.
#816
Cant wait to run my 7R!!
#817
#819
The baffle are taller which causes the clunk to stick in the up position when you flip the vehicle. Myself and others usually upgrade the type of fuel line trim the baffles and test throughly before running. Hope this helps
#821
New Carrier hub (e2105-b) mbx7r it 's similar mbx7.
#823
#824
