Xray XB8
#1186
I just picked up a B sponsorship from rcamerica and I'm going to order 2 Xb8.'s. 1 would be converted to electric. I already have the Fx engine, which I absolutely love. What is the best starting Setup for low to medium bite tracks? I usually like the low bite setups on most other buggies. Are there any must have option parts that I would need to get. I would rather order everything now and build it with them from the start. Also, does the stock body fit for the ebuggy, or do I need to order a different body? Thanks guys. Sorry for all the questions
#1187
On the e buggy I just swapped the parts from my converted xb9 2013 buggy to the xb8. It was seamless and a direct swap. The bodies are a different story. I always end up adding a m4 washer to make the front post higher, this helps a little. Here are what I have tried for bodies so far.
Xb9 2013 - did not work at all
Xb9 j concepts - better than stock (not the best looking body)
Xb9 2013 bitty - not bad but still tweaks the body with the batt pack
Xb9 2013 ftw night fox - best fit so far, batts still touch a little but best of the bunch.
I do not have the xb9 low downforce body (stock xb8) as I can't seem to get them back from the painter
I have not found a great option yet but then again this is in the wrong section...
#1188
all ive done is put the longer truggy outdrives on the front, and added springs between the brake pads. might need to change the air filter too as it hits the top of brake cam shaft when the body is on. also i moved the throttle link to below the servo horn so it doesnt rub on the body
#1189
oh right just checked the manual lol, i guess i can try to rotate the filter a bit, as its wearing a bit from the brake cam shaft, when the body is on it pushes it down
#1190
lol if i rotate the filter forwards it hits without the body on :|
#1191
i shimmed up the front body post.. 5 or 6mm. so the body is still lower than the front cut out on the front tower.
the stock body fits. if your battery is spaced to the rear. if you space the battery forward.. it rubs..
also, when trimming the stock body, do NOT cut at the bottom trim lines. if you do, the body wont go low enough to cover the side guards.
also, use velcro on the sides.. it helps
This is on 4s, not sure bout 6s or whatever others are running..
inbox me your number.. i can text pics if needed..
#1192
TV Set up from dnc is a good starting point for med grip its what I started with its on this thread page 30ish maybe. All I have done myself is add more drop in the rear. As most hsve stated need to kno what car is doing and where it needs to be tuned.
My ? Is how did u get a 48t gear on there I tried and it hit chassis?
Im running a 45t losi till the 46 comes but I might not take the 45 off its working good
#1194
Well after trying just about every single brand this year I'm really digging the Xb8. Even had the Xb9e. Which did not have enough steering for me. I put TV's DNC set up on the xb8 from the start. Been to a few tracks already with it. I want for nothing. I put it down and drive it! Its very balanced, easy to drive. You can push it or run tight lines hugging the pipes. Car does exactly what u tell it to do!! She is a keeper! Now to build a ebuggy.
#1198
Yeah I did the same. They have to be cut and bent. It sucks. What the f is the hold up with front sway bars?
#1199
In front of the tray there are two screw holes of size 4x4mm, so in practise the whole area 90x35 cannot be utilised, more like 86x35 or 90x27. Hope my explanation makes sense and didn't cause confusion...
#1200
it may be worth noting that there is a tab on the lid that will reduce the width by maybe a couple of millimetres, depending on battery dimensions
edit, its on the long side of the lid i think the side furthest from the servo as picture above shows servo mount
