Mugen MBX7T
#856
R/C Tech Elite Member
Trader Rating: 123 (100%+)
I am looking for a 7tr if anyone has one they want to part with.
We ran a friend's truck at the Nationals warmup race and loved it! We ran the HTD diffs 12/12/6 and the 7.25 and 7.75 springs. Rear hubs in the lower hole and spaced back. Front arms forward, rear arms back. Camber links long and on the lower hole on the tower. The rest of the set up was the kit setup. Dialed!
#857
New to Mugen, bought a 2nd hand MBX7TR. The guy I bought it from claims 10 races, and both bevel gears are shot. Is it a commen problem with MUGEN, soft bevel gears. I have a TLR 3.0 TE, and running it for a year now, with no problems at all???
#858
With any truck the shimming of the ring and pinion will have an effect on the life of the gears, but the Mugen ring and pinion is very durable in my opinion.
#859
If you hear the truck clicking after landing or just on the gas, it's to loose.
#860
yes. the 46T f/r are too big for the diff housing and rubs on it and not where you are supposed to dremel away. The sun gear touches the entire diff case front and back causing major drag brake the whole time. I need to get a lathe and cut 1/2mm off the circumference but imo, you do not need them with truggy. save your money unlike i did
#861
Can you please send me photos of this? I think there may be a problem because this is not normal with the HT diffs. Thank you. [email protected]
#862
#863
Ive been having some trouble with an MBX7TR and a MBX6T, we cant seem to get them to stop eating thru clutches. Tried diferent gearing, always fresh built diffs with stock silicone oils, fresh bearings and gears look good.
Anyone had this trouble before?
#865
If the spur is worn bad it will be hard on the clutch bell and bearings. The Flash point engine mout will extend bearing and gear life because it reduces flex.
#866
Check for excessive slop between bearing and the crank. I had a picco motor blow a bearing out in a main. RAN the whole race and didn't flame out, but it wore grooves in the crank. Tore through bearings left and right.
#868
#870
Does anyone know if the Arrma Typhon 17mm wheel hub will fit the 7tr? I'm wanting to find some red hubs.
