Mugen MBX7T
#271
Stock setup felt bouncy. Tried losi 45wt all the way around without rebound, no lift. Running 10,10,3, have no issues with turning that's good. Had to change pillow balls to steel because of breaking and didn't want to risk anymore so I changed them all, doesn't feel bad. Going to try Drew setup from here and see what happens.
#272
My eco turns not slides. Your setup to me sounds like you are trying to lock the rear end and have more rear traction. That can also hurt steering into a corner if you make the rear too "lazy". As for tires, I am coming to your track for the futaba challenge and I will have m3 holeshots and m3 blockades.
#273
#274
I just recently bought my MBX7t eco through amain, I like it. Completely stock setup and I haven't had any issues with breaking pillowballs / a arms. I've run almost 10 packs through it, So just over an hour of run time (70 minutes). My track doesn't have huge jumps but most of the require a lot of power to make it over them, Kind of like mount thornhills (2014 nats track) jump right after the scoring loop. I can't wait to run it more, Tons of steering with the stock setup.
#276
So I'm trying to sell my extra eco kit so I can get a nitro kit but looks like that's not going to happen. I playing with the idea of buying the nitro stuff to convert the eco to nitro. Are there any of the x6t parts that are different from the x7t?
#277
#279
#280
You guys are running that high in the back? I'm running 37-40 and have been running it for quite a while. What will an extra 6mm in the rear do?
#283
