Like Tree12Likes
Tekno NB48
Old 03-18-2014 | 08:28 AM
  #976
FastPete's Avatar
Originally Posted by vandalzzz
All three diff cases have very-very tight fit into metal spur gears. Is it ok, anyone experienced same 'feature'? Should i grind some plastic with sandpaper?
Noticed the same thing, they do go on just tight. I thought about breaking the edge on the OD.
FastPete is offline
Old 03-18-2014 | 04:27 PM
  #977
Hoese37's Avatar
When I did a dry fit, the rear was really tight. I did chamfer the OD and it slid right in with out a problem.
Hoese37 is offline
Old 03-18-2014 | 05:21 PM
  #978
vandalzzz's Avatar
Also i've noticed that web manual says go into 5C holes for rear camber link, but printed version has 6D position for this. Which one is correct for 'kit' setup?
And what about drop screws? They're supposed to be downwards in rear arms, and upwards in front arms.
vandalzzz is offline
Old 03-18-2014 | 05:59 PM
  #979
teknorc's Avatar
The setups on the web are newer setups. You could start with one of those rather than the kit setup. Either way, pick one and follow it exactly. Then make changes from there.
Yes the droop screws are reversed in front to get more droop if necessary.
teknorc is offline
Old 03-18-2014 | 06:31 PM
  #980
vandalzzz's Avatar
Thanks for info about setups.
About rear droop screws: if they're supposed to be placed heads down, how can i reach their hex sockets after assembling whole buggy? I suppose that they gonna be blocked by the droop pads on the chassis, or i missing something?
Old 03-18-2014 | 06:37 PM
  #981
JsK's Avatar
JsK
R/C Tech Elite Member
There is a Hex in both ends.
JsK is offline
Old 03-18-2014 | 06:54 PM
  #982
vandalzzz's Avatar
Mine in Bag H looks exactly like that (part no. also from manual) and doesn't have any hex on the end of thread section unlike droop screws on my ebuggy, that's why i'm a bit confused.
Old 03-18-2014 | 07:17 PM
  #983
BigInJapan's Avatar
Yeah the ones in the NB48 don't have a hex in the threaded end. I just adjust mine in small increments by compressing the shocks to get to it
BigInJapan is offline
Old 03-18-2014 | 07:20 PM
  #984
YANMAN's Avatar
Mine are the same way. I have no hex head on the screw end. I was thinking you just run full droop all the time.
YANMAN is offline
Old 03-18-2014 | 09:05 PM
  #985
DBL15's Avatar
you can get to the droop screws easy as when its all assembled no problem
just lift the arm a bit and the screw head is there
DBL15 is offline
Old 03-19-2014 | 02:12 AM
  #986
JsK's Avatar
JsK
Serves me right for not checking, i just assumed they had the hex in the end.
JsK is offline
Old 03-19-2014 | 05:54 AM
  #987
Bernard_Jr's Avatar
Default Aluminum Axle Update
I'm swapping out the bearings in my NB and wanted to give an update on the Sylveris RC aluminum axles. I probably have about 2-3 hours of driving on the axles so far and they show no signs of wear or damage.
I'll be heading up to PNB next week and that track can break anything so I'll let you know how they do.
Bernard_Jr is offline
Old 03-19-2014 | 08:01 AM
  #988
Numburn's Avatar
Just get some Mugen droop screws. You can adjust from either end.
Numburn is offline
Old 03-19-2014 | 08:31 AM
  #989
mr240 is offline
Old 03-19-2014 | 09:13 AM
  #990
+3
masher81 is offline
