Like Tree12Likes
Tekno NB48
Old 01-14-2014 | 08:47 AM
  #601
Considering to buy that kit. What kind of shoes are you using other then the stock and are you getting a lot of usage out of the stock shoes/springs? What about the engine positioning and lipo size that will fit in there?
Big_one is offline
Old 01-14-2014 | 08:57 AM
  #602
At what point do you clean/change the air filter(s)? My outer one is dirty outside, but inside is still pink maybe 1/8 inch deep. Inner one looks like the day I installed it.
Boss Ross is offline
Old 01-14-2014 | 09:00 AM
  #603
I'd just clean the outer myself. To anyone fairly new to nitro, I highly recommend a light outer filter kind of cover. It's basically like a panty hose kind of material, and it DRASTICALLY reduces air filter mainteance.. Here in Germany they're called Robitronic Dirt Bags. What brand names are available to you I don't know..
Herrsavage is offline
Old 01-14-2014 | 09:54 AM
  #604
Suspended
What would work better on a tighter track? Mugen or tekno?
Eddy1513 is offline
Old 01-14-2014 | 09:55 AM
  #605
ferrarieeeee's Avatar
I simply use my old 8ight clutch and shoes, seems to me they are the same things
ferrarieeeee is offline
Old 01-14-2014 | 09:57 AM
  #606
Tekno for sure imho
Old 01-14-2014 | 10:12 AM
  #607
kman16jr's Avatar
both can work well on the same track but coming from a mugen to the tekno my tekno definately has more rotation than my mugen did,my mugen seemed to work better on bumpier more open tracks,my tekno seems to work better everywhere now that i have found some setups for other tracks.
kman16jr is offline
Old 01-14-2014 | 10:26 AM
  #608
Originally Posted by 1evo RRR Driver
Looks awesome, but I think your steering link is a bit short! Your servo arm as really angled n your wheels r straight.......my OCD would kill me if it's not all centered
Fixed that right after I took those pics.
mr240 is offline
Old 01-14-2014 | 10:37 AM
  #609
The shoes and springs are just like the Ascendancy setup I was using in my 6T. That setup I got 4 gallons before I needed to replace the shoes. So I would expect the same with the Tekno shoes. As for the lipo. I am using this one. Needed to put some foam in battery compartment so the battery does not move around. http://www3.towerhobbies.com/cgi-bin...?&I=LXDWWJ&P=7
mr240 is offline
Old 01-14-2014 | 10:57 AM
  #610
so I guess the losi style protek wont work. As for the losi clutch I always disappointed with the life from those shoes...
Big_one is offline
Old 01-14-2014 | 11:18 AM
  #611
teknorc's Avatar
Pretty sure any shoes made for the Losi car will drop right in.
teknorc is offline
Old 01-14-2014 | 11:31 AM
  #612
Cool. What about the motor positionning?
Big_one is offline
Old 01-14-2014 | 11:59 AM
  #613
Bernard_Jr's Avatar
Can you explain your positioning question a little more? Are you asking if it's further forward than normal or about the two mounting options?
The car accepts hump packs only. I use a Revtech 2500mah hump pack. That measures 31 x 32 x 55mm. I added a piece of foam padding that was about 1/16" thick to take up the play in the box.
http://www.trinityrc.net/shop/index....product_id=354
Bernard_Jr is offline
Old 01-14-2014 | 12:10 PM
  #614
Suspended
ok thanks, one more ?, is it durable? I love the mugen but its not durable, thats why im considering buuing this.
Eddy1513 is offline
Old 01-14-2014 | 01:01 PM
  #615
Bernard_Jr's Avatar
I switched from a MBX-6 electric conversion to the EB and the Tekno has been way more durable. It's very nice to have a car that the arms fit either side which means I don't have to have as many spares. Plus it shares parts with my SCT and now the NB. I've yet to break anything on my EB but I did break several front/rear arms and bent hinge pins on the Mugen. I was also replacing the steering tierod ends often because the wheels rubbed at full lock and it still didn't turn enough. The Tekno also has no slop and is much easier to work on.
I agree with everything that Kevin mentioned before about the Mugen handling the rough better but it's because it weighs so much more. Someone asked me to compare the two when I first got the Tekno and I told them the Mugen was more like a Cadillac, easier to drive but slower, and the Tekno was a Porsche, same equipment was way faster (much lighter), more nimble, and it wants you to drive faster.
I love my Tekno stuff. I don't dread working on them because all I every have to do is clean it.
