Like Tree12Likes
Tekno NB48
Old 12-13-2013 | 11:48 AM
  #391
Bernard_Jr's Avatar
Originally Posted by howse
Before I used a mugen Mbx6. It seems like it binds on the flywheel hole of the chassis before it will hit the flywheel.
Hope you get it figured out. I bought the same box. Let us know how it goes.
Bernard_Jr is offline
Old 12-13-2013 | 12:23 PM
  #392
i got it aligned as much as i could but it will hit the flywheel but not enough force to turn the motor over, anymore force and it just binds on the flywheel hole (chassis) to be fair it is a new motor and its pretty tight.
maybe i should just get the suggested box teknorc?
http://www.amainhobbies.com/product_...ad-Starter-Box
howse is offline
Old 12-13-2013 | 01:15 PM
  #393
teknorc's Avatar
The box you linked to is what I use. A new engine is going to be trouble on any box unless you heat it up real good.
The only issue with the box linked above is that the motors burn out on 4s unless you put a Losi wiring harness on it (http://www.amainhobbies.com/product_...e-Hardware-Set).
The Losi box requires a lot of mods, but works really well. We're really impressed with the Hudy box, but it's expensive. I think the Hudy box would be my first choice.
teknorc is offline
Old 12-13-2013 | 03:14 PM
  #394
I recommend this box, it is amazing. I have broken in about 3-4 motors with it and had zero issues.
http://www.amainhobbies.com/product_...gy-Starter-Box
steve blair is offline
Old 12-13-2013 | 05:15 PM
  #395
spunkysandoval's Avatar
I'm using a losi RTR box I've had for a long time. It works perfect.
Here is a few pics of my build. Went very good. Only thing that I want to mention is the steering block screw hits the arm when turning at full droop. I just flipped the screw around and it was good to go. You could also fix it with a few washers, but i decide to just do this instead.
Also, incase anyone wants to run a steel flywheel, the serpent steel flywheel is a direct replacement. All of the tekno clutch parts can be used (screw pins, shoes, pins). You will need to use the serpent clutch bell though because the tekno bell uses a larger diameter bearing on the inside that doesn't fit inside of the serpent bell. Steel flywheel is good for smoothing out the power delivery and reducing flameouts.
Quick rattle can. I really like this body Tekno!
spunkysandoval is offline
Old 12-13-2013 | 05:46 PM
  #396
teknorc's Avatar
Nice build, Isaac. I notice you didn't put the camber links in the stock recommended holes . The long link in the front will make the car twitchy. We highly recommend starting with the stock setup for camber links.
We are also putting 2 degrees camber in front and 3 degrees in back. This tames it down a little more and improves corner speed.
There will be a lot of NB48's at CVRC this weekend - should be a blast! See you there!
teknorc is offline
Old 12-13-2013 | 05:47 PM
  #397
teknorc's Avatar
Thanks for the link, Austin. I'll pick up one of those too and try it out.
teknorc is offline
Old 12-13-2013 | 06:10 PM
  #398
GrimReminder's Avatar
Danny,
I'm very curious and maybe you have answered this is the past. Now that you're producing nitro kits, I think it would be a great I idea for Tekno to produce a starter box that will accomadate the buggy and truggy, is this possible?
GrimReminder is offline
Old 12-13-2013 | 07:28 PM
  #399
https://www.youtube.com/watch?v=qY5L...e_gdata_player
Here is my first few laps with the nitro buggy. Went up in shock oil in the rear shocks after this run.
PUDDIN is offline
Old 12-13-2013 | 07:49 PM
  #400
I use an OFNA blue as well. Had to pull the motor and reverse the rear plate to line it up. Works great now.
Boss Ross is offline
Old 12-13-2013 | 08:44 PM
  #401
FastPete's Avatar
Originally Posted by EVERRET
I Found a Great deal........ so I went ahead and pulled the trigger on my first Tekno !
fiercercsolutions.com
(Thanks Pete !)
Super fast delivery , so I should be able to get it get it built this weekend.
Thank you, thanks for the kind words! And good luck you wont be disappointed
FastPete is offline
Old 12-13-2013 | 08:45 PM
  #402
FastPete's Avatar
Looks good!
FastPete is offline
Old 12-13-2013 | 08:49 PM
  #403
teknorc's Avatar
Originally Posted by GrimReminder
Danny,
Yes, it's possible and it's something we're considering. Probably wouldn't be for a while if we did though. A few other projects are first. Thanks for the suggestion.
teknorc is offline
Old 12-13-2013 | 08:51 PM
  #404
Sta-bil's Avatar
which way is the motor setup? (forward or back)
Sta-bil is offline
  #405
teknorc's Avatar
Thanks for sharing, Matt. I'd love to see an after video with changes you made if you get the chance. Thanks again :-).
teknorc is offline
