Like Tree12Likes
Tekno NB48
Old 10-02-2014 | 02:06 PM
  #2536
madweazl's Avatar
Hot damn, Larry Genova over at Kustom R/C Graphics finished up the body today so it should be here in time for JBRL! I've been using him for a few years now and he always adds a little something to one up the previous version. This time it was the window trim which I love!
madweazl is offline
Old 10-02-2014 | 04:52 PM
  #2537
vandalzzz's Avatar
Looks good.
Could you make some photos of the outer fuel line clips with FTW body on?
vandalzzz is offline
Old 10-02-2014 | 04:57 PM
  #2538
madweazl's Avatar
Sure, I'll write everything I find just like with the BittyDesign body I tried.
madweazl is offline
Old 10-02-2014 | 05:38 PM
  #2539
EJF's Avatar
EJF
Is the stock ( kit ) clutch any good? I see most run the losi stuff, any reasoning behind this?
EJF is offline
Old 10-02-2014 | 06:11 PM
  #2540
madweazl's Avatar
It's essentially the same thing. I'm still running the stock clutch with kit configuration and really like it. With that said, I picked up Werks clutch and will be running it from here on out because they're just so easy to work on.
madweazl is offline
Old 10-02-2014 | 08:10 PM
  #2541
FastPete's Avatar
Hot Dam no kidding looks beautiful!
FastPete is offline
Old 10-03-2014 | 12:41 PM
  #2542
I personally love the stock clutch. I know a few losi guys that have been running the tekno shoes here locally. The only thing I don't like is how fast the tekno shoes wear. But i love how they feel.
masher81 is offline
Old 10-03-2014 | 12:48 PM
  #2543
Graham11's Avatar
I would say the Tekno shoes wear the same as losi but if you want something with more life try the Dynamite max Life shoes, they last foreever and performance doesnt seem to suffer in my opinion
Graham11 is offline
Old 10-03-2014 | 12:50 PM
  #2544
I have been running the Max life shoes actually.
masher81 is offline
Old 10-04-2014 | 09:27 PM
  #2545
madweazl's Avatar
Ran the Mugen series down at Heritage RC today and had a blast as usual. I hadn't run the Tekno there until this morning and my setup showed. Track was kept fairly wet which didn't compliment the X2 compounds I had brought despite the 95 degree temps. Setup was a little more nervous but decent. Ended up qualifying 3rd but could only muster a fourth place finish after a computer failure forced a restart while I was running second in the A. Kept making mistakes on a trickey infield double that seemed simple but kicked my butt for some reason.
Hoping to do better at next week's JBRL and then come back down and snatch up a podium at the next Mugen series in two weeks.
madweazl is offline
Old 10-05-2014 | 03:24 AM
  #2546
Did you do any testing at Rev? I am currently running Mo's setup, but will be changing to the 1.5 pistons on the NB. The EB is already setup with the 1.5s and feels really good. Just curious as I have not been able to run it, but should be down there on Fri. May have to hunt you down to pit near you or see where the rest of the team is pitting.
Stirex is offline
Old 10-05-2014 | 07:40 AM
  #2547
madweazl's Avatar
I've spent a lot of time at revelation and Mo's setup works really well there (95% solution). I haven't tried the 6.5 pistons yet. Lots of tires work well there but Catapults seem to be about the best.
The layout hadnt changed as of Wednesday. I'll be heading back down Tuesday to work on a few things again and will provide some info on the track if there are changes.
madweazl is offline
Old 10-05-2014 | 07:58 AM
  #2548
madweazl's Avatar
Forgot to mention my "fail" for the day at the Mugen race; came in for fuel at the end the warmup laps during the first qualifier and upon exit pulled a nice little barrel roll. Not real sure what happened to cause it but I was probably too hard on the binders and caught a rut. Got a nice DNS after check in. Durango turnbuckle cracked so I quickly removed all of those and went back to the stock units.
Changed clutch bearings after the second Qual and found a tooth missing on the clutch bell. Had a Serpent on hands so that was a fairly easy fix (needs a longer collet but I had one of those thankfully).
Haven't torn down the buggy yet but there are no other obvious issues. Still not happy with the braking, not sure what I'm going to try next in that department.
madweazl is offline
Old 10-06-2014 | 04:12 AM
  #2549
vandalzzz's Avatar
Default Pics
Some pics (not mine) from last Regional Rd:
Old 10-06-2014 | 01:19 PM
  #2550
FastPete's Avatar
Great pics.
FastPete is offline
