Like Tree12Likes
Tekno NB48
Old 07-06-2014 | 11:17 AM
  #1726
Hoese37's Avatar
Originally Posted by Cappy
Anyone else having problems eating up clutch bell bearings in this car ?
Sounds like you need to shim it a little tighter.
Hoese37 is offline
Old 07-06-2014 | 11:21 AM
  #1727
Or its already to tight........I have found that is the biggest problem when eating bearings
RockStar_199 is offline
Old 07-06-2014 | 11:58 AM
  #1728
Cappy's Avatar
so you guys dont think its a chassis flex issue chewin bearings from the twisting of the gear mesh ?
Cappy is offline
Old 07-06-2014 | 01:01 PM
  #1729
Graham11's Avatar
It's def a shim issue, my OS Speed would eat bearings all day but my RB never needs bearings and it's cus the shim and bell set up are better on my RB engine
Graham11 is offline
Old 07-06-2014 | 01:29 PM
  #1730
Cappy's Avatar
ok i though i had enough play in the bell to when it heated up it would get too tight but i guess not. was runnin a lil lean in the main Saturday so maybe got hotter then it should have.. But i was savin gas...
Cappy is offline
Old 07-06-2014 | 03:42 PM
  #1731
Mel's Avatar
Mel
The bearings don't last long at 350 + on the motor... sillly
Mel is offline
Old 07-06-2014 | 04:25 PM
  #1732
DBL15's Avatar
i used to chew through them as well when i was shimmed to tight
i now make sure i have play and they have been fine getting nearly a mouth of us out of them compaired to only a couple of 10 minute races
but yeh looser is working for me
DBL15 is offline
Old 07-07-2014 | 02:18 AM
  #1733
Cappy's Avatar
Your such a Hater
Cappy is offline
Old 07-07-2014 | 07:16 AM
  #1734
Graham11's Avatar
Just finished painting my new body over the weekend. Already showed the Tekno team but figured other NB48 drivers may like some pics for ideas for their own kit.
Attached Thumbnails Tekno NB48-tekno1.jpg   Tekno NB48-tekno2.jpg   Tekno NB48-tekno3.jpg   Tekno NB48-tekno4.jpg
Graham11 is offline
Old 07-07-2014 | 07:24 AM
  #1735
FastPete's Avatar
Looks great nice job!
FastPete is offline
Old 07-07-2014 | 07:28 AM
  #1736
offroad dude's Avatar
Me likey......
offroad dude is offline
Old 07-07-2014 | 03:25 PM
  #1737
CAR
Tekno.... When are we going to see a fix for the diff shims? I have been replacing my dirty black diff oil and replacing with new shims after every other day of racing and I am sure that with all the metal in the oil the gears and cross over shafts will be the next thing to replace.
CAR is offline
Old 07-07-2014 | 03:53 PM
  #1738
Default Brands
Can't you use another brand?
latemodel13 is offline
Old 07-07-2014 | 05:15 PM
  #1739
Why are you replacing diff shims. Are you leaking diff oil.
mr240 is offline
Old 07-07-2014 | 05:33 PM
  #1740
DBL15's Avatar
agreed mine was the 1st batch out of factory and 4 months or so and i open diffs and there still full dirty yes but full no leaks
kind of a bit lost on these diff shims every one is talking about ?
DBL15 is offline
