Like Tree12Likes
Tekno NB48
Old 06-17-2014 | 04:30 PM
  #1591
Casketman's Avatar
EDDIE!!
<--Drew
Casketman is offline
Old 06-17-2014 | 04:38 PM
  #1592
DBL15's Avatar
Originally Posted by EJF
So what is the general opinion on this buggy? Any areas of concern as far as durability or wear? Handling wise? Consistant from track to track?
consistant = very
tough as nails
handling so many options and this thread and Tekno site very helpful for set up sheets if needed
all good if you make the move you will want the truggy as well so be ready as its awesome as well
DBL15 is offline
Old 06-17-2014 | 04:40 PM
  #1593
DBL15's Avatar
Originally Posted by Numburn
I've seen a lot of people switch to the Losi air filter.
yes i do as i feel they protect the motor better and there foams seal better and after market options from protect and lucky 7 filters work well
DBL15 is offline
Old 06-17-2014 | 04:43 PM
  #1594
EJF's Avatar
EJF
Seen the truggy in action... decent driver and he was turning laps INDOOR as fast if not faster than the top buggy drivers
EJF is offline
Old 06-17-2014 | 04:47 PM
  #1595
Casketman's Avatar
So what is the general opinion on this buggy? Any areas of concern as far as durability or wear? Handling wise? Consistent from track to track?
Ok,I love the car! Turns on a dime. The stock setup to me is perfect for those who are drifters around the corners...But I'm not. I finally got the rear under control,I still turn under people and now I can gun it and keep it straight out of the corner.
The car has taken a beating from me mainly at the first race and it did finally break,but when you pound away at the left front and then finally land the car on it's side to top it off,yeah,something is going to give and the left front did. But besides that and a bent rear center drive shaft. The car has been great. Hell,in my 5th race with it,I took second(should of been first) last weekend at the Midwest Nitro race at Clark RC in Wisconsin.
As for the drive shaft,I was running just one long brace in back. I've put the other short brace in and I didn't notice it bending again so running both braces must fix that.
I ran the D812 over the winter and never felt comfortable with it. Ran the MBX6 last summer and never felt comfortable with it. This car,I'm feeling comfortable with and it just keeps getting better.
Old 06-17-2014 | 04:58 PM
  #1596
Originally Posted by teknorc
I think I see what you're talking about (please post a pic though). Make sure the set screws on the linkage are not pointing straight up. Rotate the link so they are to the side but still accessible, then they shouldn't catch on anything. Does this make sense or am I missing the issue?
Originally Posted by underway
Here are the photos of my linkage.
And my set screws are pointing up(gonna change it now)
Thanks, no doubt you have more clearance. I double checked the manual and it appears to be all assembled and setup right for the engine in a rear position. I've tried the link to the right down lower and the linkages rub and are close to the foam. Here I have it to the left in a straight fashion with the carb. If I rotate it counter clockwise it will no longer be aligned and will rub with the servo horn slightly.
Based on the amount of space you have, I must be doing something wrong, but I'm not seeing what it is.
Engine is a werks b6 for what it's worth if somehow something is different there.
RokleM is offline
Old 06-17-2014 | 05:01 PM
  #1597
Originally Posted by DBL15
consistant = very
tough as nails
They had a little bit of a rocky start with the fuel tank issues, but fixed that in no time flat in comparison to some other companies (some other companies would sell you an upgrade, tell you it was your fault, or just plain ignore the issue).
What DBL15 said, plus the "family". Go into the other manufacture threads and you see bickering, people fighting, people making fun of one another. Every Tekno thread pretty much is one of the most civilized and informative on RCTech. The company and the people that seem to pick them just... well... seem to get along and help each other.
RokleM is offline
Old 06-17-2014 | 05:35 PM
  #1598
Default Buku clutch
Anyone running buku clutch? What bell did you use?
blacktop20valve is offline
Old 06-17-2014 | 06:25 PM
  #1599
BigInJapan's Avatar
I'll give my opinion too...
STeering is right up there with the best in 1/8. It feels like a new-gen, modern buggy. Love the look, and feel. I was comfortable with it right away. Looks and feels small, agile and quick. Wicked corner speed. You will constantly turn under others Mine weighed in at slightly over 100 grams less than an mp9, ready to run. The shocks get a special mention too. I run mine with the TiNi option shafts, and they are seriously good, even with stock setup pistons etc.
There is a small downside, and that is consistency at tracks that change during the day. If you set up for slower steering on a loamy or dusty track, and it changes to blue groove or high traction, the back end will lock down and you'll want more steering, and vice versa. But this is a normal racing issue, and will affect all buggies, plus it's just my findings on the tracks I run anyway.
Durability, all buggies gonna have issues, this had some, may still have some, but all said and done, no concerns for me about durability, or premature wear.
SIcK buggy.
BigInJapan is offline
Old 06-17-2014 | 07:09 PM
  #1600
vandalzzz's Avatar
How smooth are your diffs? I build mine as per manual, with one stock shim behind every sun gear, four lockscews aren't overtightened. But i can feel gear teeth when i pick diff and rotate out cups in opposite direction. It doesn't bind in any terms, but it isn't smooth like diff on my ebuggy. Overall performance is good, there are no signs of heavy diffs, but i'm a bit worried: is it ok for tekno vehicles to have not so butter smooth diff internals?
vandalzzz is offline
Old 06-17-2014 | 07:12 PM
  #1601
FastPete's Avatar
Originally Posted by jay13111
Almost ready for my first run on Saturday!
Sweet enjoy!
FastPete is offline
Old 06-17-2014 | 07:13 PM
  #1602
Bcholka's Avatar
SIcK buggy.
Very good and accurate writeup!!!!!
Bcholka is offline
Old 06-17-2014 | 07:14 PM
  #1603
Bcholka's Avatar
We have 6 Tekno's (but who's counting LOL)--all the diffs have a very slight notchy feeling to them--nary ever an issue--should be fine!!
Bcholka is offline
Old 06-17-2014 | 07:38 PM
  #1604
BigInJapan's Avatar
I can feel the gear teeth on mine too. Will depend slightly on the thickness of oil, the thicker you run, the more 'locked up' the diff will be and so you have to put more pressure on the out drives to turn them, thereby feeling the gears mesh more. I'd say nothing to worry about. Just for info, its the same with my xray diffs
Old 06-17-2014 | 08:10 PM
  #1605
I also find the tekno diff's to be a little "rough" in comparison to others when tested by hand, but to be honest you won't feel it on the track. It performs smoother than other vehicles I've run.
RokleM is offline
