Hot Bodies D812
#6436
Anybody ever run without the arms inserts?
#6438
#6439
#6440
#6441
#6442
#6443
Hot Bodies
@Gord- would a piston with a lot of small holes achieve that goal? Something like a10x.9mm for example. I really have limited experience in testing pistons so just thinking out loud here.
@slakr- I remember from my Kyosho days, the thickness of the wheel hexes, which widens or narrows the track, makes a noticeable difference in handling. It might be worthwhile checking to see if the Mugen hexes are the same width as the Hot Bodies ones.
#6444
Need help on this fellas had a bit of bad luck yesterday broke a part of the rear universal drive shaft assembly manual has the part listed as a 109857-a. but when i look up that part number its giving me the whole assembly..
109857-a connects to the drive shaft 109857-a goes through the hub then the 17mm wheel adapter goes onto to it..
Can anybody help me with this part number I dont wanna buy the whole assembly if i don't have to
#6445
You need to buy the entire assembly.
#6446
Hope that helps.
#6449
If I were to spend 40$+ I'd go ahead and upgrade to mugen front universals
#6450
Aside from the lack of possible self disassembly, is there any other benefit to one piece universals that a nOrMAl person could detect? Drawbacks?
