Mugen MBX7
#4426
noticed both my rear shock shafts were bent tonight while getting ready for a race. When I replaced them and rebuilt, my csi pistons didn't want to fit smoothly in the shock body. Do you think the piston could be warped or maybe shock body tweaked? Went back to a mugen piston and it seemed to work fine in the shock body.
#4429
Jamie
#4431
Yes you cut the spring down a fair bit, especially if you want to run the collet also.
With the pillowball play adjustment check you have a slight amount of play still at full lock, when adjusted them that close with the steering straight ahead they will be too close at full lock, running them too tight can actually wind the alloy ball off over time.
With shock rebound you don't want much rebound, but I have noticed the shocks seem to have less when first filled before any oil and air is blead out, then I just crack the shock open a full turn holding it on an angle with the bleed hole facing up, push the shaft1/2 way in for some slow rebound or 2/3rds to 3/4 in for next to no rebound...and good tip made in a post above, do not tighten the locknut too tight on to the piston.
#4432
Got my kit to a roller last night. The quality and fitment is top notch, probably the best in the business. I actually lost time trying to shim things that ended up not needing to be shimed (Ie. diffs in diff cases) Now i'm at a sticking point...racing tomorrow and I still need to pull all of the electronics and engine out of my old car and set up the starter box to run the X7 or get some good sleep and race the 8.2. I so want to run the X7 tomorrow but that pesky thing called a job is keeping me from finishing now.
#4433
Good morning Mugen peeps. I am picking up my new 7 on Sunday and want to order a few more parts to complete the build. I have read about the throttle servo arm problems and want to know if the Hudy arm I bought for the six will work for the seven. Does anyone know if this arm will work on the seven without major modifications?
http://www.absolutehobbyz.com/advanc...ords=HUD293495
Also, the JQ spacers are sold out everywhere I have looked, does anyone know if they are in stock anywhere?
Thanks, Mike
Thanks, Mike
#4434
Thanks, Mike
Thanks, Mike
http://www.amazon.com/dp/B004KRMHCI/...I&linkCode=asn
#4436
As for the bladders, I changed them to Kyosho bladders. Rebound is much more consistent and easier to setup. It's a tip I got from Daniel Reckward when he was still driving Mugen.
#4437
I cut a little of the spring and also cut the conical end of the ballend of so I have more place for the collet
#4438
I have never ran the Collet just for that reason. Sometimes have to cut the spring depending on the engine as well.
#4439
#4440
