Drag Racing Truggies >
Old 07-29-2012, 01:24 PM
  #31
GizmoJunkie's Avatar
Originally Posted by hookem34
M2C is what you want for your application. Shoes are 1.5g each.
I havent tried the m2c myself, but i have used the werks pro clutch for a while and like it, its a solid clutch kit. The concept seems similar between the two, what would be the difference?
With that said. I do have a little experience between the werks and the buku. Ive had the buku a couple of weeks now. It is externally adjustable, and you can adjust it to grab however you like. Dont let 3 vs 4 shoe throw you off.
Just be open minded before you dismiss things that may indeed work wonders for your application.
GizmoJunkie is offline
Old 08-05-2012, 11:26 AM
  #32
What fuel are you all running in these motors?
LOCK_DOWN is offline
Old 08-07-2012, 01:27 PM
  #33
low_dakota94's Avatar
Trader Rating: 22 (100%+)
I'll post a few pics of both of my truggies to give you some ideas. In my opinion it's my favorite class to run at our local events.
low_dakota94 is offline
Old 08-07-2012, 07:08 PM
  #34
Old 08-08-2012, 10:58 AM
  #35
rustlererad3's Avatar
Wow they look awesome and since you seem to be a truggy veteran would you mind offering me some truggy advice
rustlererad3 is offline
Old 08-08-2012, 08:29 PM
  #36
I can offer up as much help as I can. Shoot me a pm and we'll see what we can figure out.
Old 08-10-2012, 06:01 PM
  #37
It looks nice but what kind of times does it run?
Old 08-10-2012, 08:39 PM
  #38
Old 08-10-2012, 08:56 PM
  #39
I remember racing a Sportwerks Mayhem Truggy. Fun times. Now it's only buggy racing.
KaraokeBarStar is offline
Old 08-11-2012, 08:17 PM
  #40
Those are some really good numbers I would like to run those numbers consistent that sounds good to me. Do you run in a Truggy class or what else do you race against?
Old 08-12-2012, 04:33 AM
  #41
Trader Rating: 87 (100%+)
Drag racing a truggy...sounds like a blast!
Truggy = MBX6T (so many gearing & shock setup options you'd be set there)
Motor;
Electric = Tekin 2250 or Castle 2200kv both on 6s
Nitro = Radical 621T
Have fun & Best of luck!!
djs101 is offline
Old 08-12-2012, 10:18 AM
  #42
Old 08-12-2012, 06:05 PM
  #43
Wow so you are beating Jato's with this Truggy I never thought that a Truggy would compete with a Truggy. What kind of clutch do you recommend for a Truggy, because I hear that they eat up a clutch really fast.
Old 08-12-2012, 06:13 PM
  #44
kgombe's Avatar
Scale drag racing is 132feet.. a jato with allot of power in will want to wheel off the line and thats not really good even if you put wheelly bars on it...which means you have to come off the line with a little throttle control or set your expo on your radio.. with a truggy that has enough power you can get on the throttle right of the bat and just try to keep it straight... so it isn't on heard off that a jato will get beat...
kgombe is offline
Old 08-12-2012, 07:10 PM
  #45
Ok I'm a rookie to drag racing by far, but should I start off gearing with smaller tires or bigger tires. And I understand that it maybe possible to beat Jato's but I have learned in racing the fastest car doesn't always win. There are a lot of other key factors in racing. There are rules and regulations that could get you kicked out of the race. And I could expect a tricked out Truggy to beat a stock Jato but a tricked out Jato I am very amazed to hear that.
