Drag Racing Truggies
Im interested in drag racing a Truggy in 132 feet. Which Truggy do you recommend and what motor and gear combination would you run?
clockwork racing mod .28
buku clutch
buku clutch
What Truggy will be able to handle the power the best and what gearing and tires will be recommended?
Ive been looking at the Kyosho, Mugen, Losi, & Serpent vehicles which vehicle is the best for Truggy drag racing?
I know this may come as a shock to you, but truggies are not designed for drag racing. Drag cars are designed for drag racing. Therefor no truggy will be good at drag racing. However, truggies do work fairly well on off-road tracks, being that they were designed for that type of racing. It would be like asking which boat would would work best for off-roading. The answer is none. I mean is it really that hard to understand?
I understand that Truggies aren't built for drag racing. But there is a class coming up at our track for Truggies Drag Racing. A lot of these trucks weren't designed to do a lot of things that we make them do but it doesn't mean that it can not be done.
i would say mugen ive found alot more gear options for it .
have fun post up some pics and video .
What type of Truggies are actually holding and maintaining the power the best and what kind of tires are you all using. I'm trying to get my truck in the 2.5's or 2.4's in 132 feet. And I want a Truggy that is capable of doing that the best.
You want a kit that typically has a super free drive train.
As far as tires, it depends. are you gong to be drag racing on dirt or asphalt? You will need to find a proper tire for this as truggy tires are meant for dirt and side bite also. Your typical tires will be toast very quickly on asphalt.
If amain still has them on sale, check out the hard compound aka city blocks (they do, just looked). they seem to hold up fairly well on most surfaces. They are good for me running up and down the street anyway. They were cheap and i didnt want to use my race tires on the asphalt. $$$!
Also will need to look at options for the center diff. If you lock it, under power you will probly do nothing but wheelie like mad. You will likely need to play with center diff oils. The thick stuff lol.
The typical buggy/truggy design with your normal center diff setup allows your front tires to spin like hell under a lot of power. Esp if you go with a high end modded engine setup. You will need less power to front and more to rear.
Tons of options available, esp with some custom and "outside the box" thinking.
