Team Associated RC8.2 Factory Team Kit is coming
#2056
I built my stock diffs with one less shim behind the ring-side sun gear, still running them like that, smooth as butter.
#2058
The cases may be slightly different lengths or have slightly different tolerances as they are different materials/manufacturers. I wouldn't sweat removing a shim though.
#2059
On the RC8b, can you put the new shock towers on this car?
Looking to buy a used one or the RC8be for cheaper and use the new shock towers, and then just replace the other parts as needed.
#2060
Rob- With the newer front and rear shock shafts and the new arms, yes, the towers will bolt right on. Also use the newer boots, the older boots will not allow enough up travel.
#2061
he'll need the new swaybars too won't he.
#2062
yes good point, with the drop links, good catch
#2063
im currently running the stock setup, what would be good to change to help with a small bumpy traction with decent size jumps?
#2064
rc8.2 boots
Josh everytimw i go to amain and i was looking for rc8.2 shock boots. When i order it it comes as shock boots with rc8 on top those are very flimsy tho . Are thoae the newer boots ae is runnimg or is there a different one. Because the one i have has no structure to them .
#2065
The new style boots that come on the 8.2 are much thinner then the old stlyle ones thus much less binding but they are much less durable. As much as I was always against this in the past I stoped using boots period.
#2068
Am against it after i saw the shock oil from a buggy i bought and see what dirt can do to your shock shaft and oil. Dnt do it!!!
#2070
