NEW D8 Atsushi Hara Edition*
#1066
#1067
running 10 over 5 will give you better acceleration if you got the traction, more on power steering(not good on rutted tracks). 5 will give you more off power steering and will be easier to drive then 10 will pull from front not push. I usually stick to 5 or 7 unless im on a high speed smooth track
#1069
The d8 has been around for awhile now, so the kit setup is good, just put what the build manual says, then make small chngs from there.....trust me I guarantee u like it right out of the box!!!
#1070
Traction on the track I am tuning for is "ok" at best. It can be slick at times, more so than ever hooked up. There are no jumps right out of corners that require a lot of traction to properly make.
In trying to learn setup on the D8, I have been exagerating some of the adjustments. For example, the last race I went to, I went from 3 to 5k in the rear diff. As expected, it pushed off power. On power traction did not seem to be overly affected. Car was noticeably "less quick" in the switch back types of turns; chicanes, etc. I had to "wait" on the car.
So if I wanted to experiment, here's my thinking:
the 3k in the back was "quicker" off power than the 5k (on turn in and switch back, chicane type turns). If I wanted to quicken it up even more go to 2k in the rear.
In doing so, this may reduce on power traction (is this correct?). You wrote that 5k in the center will provide more off power steering and be "easier to drive" (you did further qualify this with "than 10k"). Can I assume that 5k in the center will be easier to drive than 7k as well?
Combining the above 2 changes, my final diff fluids would be 5-5-2 (from 5-7-3). Would this give me what I am looking for? Quicker off power without overly affecting on power traction?
Thanks - Jim
#1071
A great setup is:
7/7/3
1.3's F&R
350 F/ 400-450 R depending on temp
Grey F/ Yellow R
Then use the stock camberlinks
Outside on arms for shock position
Outside on towers for shock positions
Hubs Forward
-2 Front Camber
-2.5 Rear Camber
27mm Front RH, 28mm Rear RH
I run this pretty much everywhere. Just minor changes track to track.
7/7/3
1.3's F&R
Grey F/ Yellow R
Hubs Forward
-2 Front Camber
-2.5 Rear Camber
#1072
A great setup is:
7/7/3
1.3's F&R
Grey F/ Yellow R
Hubs Forward
-2 Front Camber
-2.5 Rear Camber
7/7/3
1.3's F&R
Grey F/ Yellow R
Hubs Forward
-2 Front Camber
-2.5 Rear Camber
Do you have any suggestions on the droop/shock lengeth?
#1075
#1077
#1078
#1079
A great setup is:
7/7/3
1.3's F&R
Grey F/ Yellow R
Hubs Forward
-2 Front Camber
-2.5 Rear Camber
7/7/3
1.3's F&R
Grey F/ Yellow R
Hubs Forward
-2 Front Camber
-2.5 Rear Camber
