NEW D8 Atsushi Hara Edition*
#812
Ok, thanks for all the info. I just built my shocks to short. i just measured my buggy and full droop on the front is 97mm, and 111mm in the rear. I was looking at Haras Pattaya setup and he was running 107mm in the front. I would assume he probably ran the truggy shock ends no?
#813
#816
well I have the c22891 24x30x55mm 1650mah lipo sitting on my bench. It doesn't fit in my battery box. I had bought it for a nitro LM. But since it was said it would fit I figured I would try. No dice, not really sure what your talking about 400. Please post a pic of yours.
#817
Sorry about that, I don't check this site often. Here are some pictures. You have to take your tray out and remove the throttle servo mounting tab. The battery slides right in without any modifications. I'm running them in both the buggy and truggy and both are averaging only 550mah of use after 1 hour of running. Best battery I have run to date. I wish HB made a flat battery cover. I'm not sure what you mean by a nitro LM, but this is for a D8 and D8T.
Is this correct?
Also, from the photos, I do not see you power nor balance plug. I assume they're somewhere outside of the battery box? Did you have to enlarge the opening for the connectors to go through?
Thanks - Jim
#818
Does this battery fit in OK, or do you need to force it in a bit? Have long have you used this battery for? Have you cycled the battery (discharged it, then balance charged it) to see what the battery capacity actually is?
The Robotronic battery loses a lot of it's capacity. I have 4-5 of them, one is 1300mah, the rest are at 1000mah or lower when the label states 1500mah. Some brand new are not 1500mah, their lifespan and Q.C. are lacking.
#819
Rarely see 30 minute mains where I race, so really not much of an issue to even come close to depleting either of these.
Just FYI. I like my LiPo's.
#820
I run the battery wire under the throttle servo and into the receiver tray. I have the battery charge lead, from the power switch, hanging outside the receiver tray so I can charge the car. I don't run a regulator as I run the savox servos and the batteries don't even get half way depleted after a full race day. I charge them in the morning and run the vehicles all day. When I get home they only need 500mah to recharge them.
I don't pretend to be a master at electronics. I just like to keep things simple. These are light, small, fit in without any modifications, and provide a full day of racing without having to recharge. I have only used them for two months now but have no issues with them. I don't get anything out of recommending these to you guys other than letting you know what has worked for me. I also see a lot of guys rushing to charge their stuff in between heats or swap batteries, when that's not necessary any longer. I've been using them for two months, races every weekend and practice about three days a week with zero issues. In my opinion, they are just as strong as when I first got them. I hope this helps. Let me know if you have any other questions. I think I answered them all.
I will cycle both batteries and post what they took.
#821
#822
he did say there must be size variation between the 2
#825
good size battery for D8
Fellas whats a good size battery (dimension) in MM to use for the D8, dont want to purchase a battery then have to modify my battery box........Or was the Hara designed to run a nimh hump, n maybe the weight is needed from that style battery??? thanks
is 54mmx31x25 good?
is 54mmx31x25 good?
