NEW D8 Atsushi Hara Edition*
#1561
are the adj. "nuts" pushing against the brake linkage mounts when giving it throttle? can you post a pic. of your linkage?
#1564
I noticed this too, great idea to put a stopper. did they design is like this so you can use the other side when it "wears" out?
#1565
i have no idea how to fix this. i've spent four hours trying to fix it but still when I accelerate my throttle servo the brakes are applied. it's ashame if I can't get this fixed by sunday as I was really looking forward to racing this buggy. Never had this issue with the RC8B and I sold that last week. Dam!!
#1566
also, take a look at the pic above. if yours look exactly like that, you should have no issues. did you use the outer most hole on the servo arm? did you measure 7mm(i think) clearance for the metal shoe? the stopper is a good idea though.
#1569
I'm assuming parts will show up then too. I'll send him another email and confirm. With the Hara car just coming out late last year, I doubt they are discontinuing parts.
#1572
This happens every year with parts because nitro season is starting up around the country.
#1573
did you test it with just the servos turned on? push the car by hand, and when you apply throttle, the car just stops dead?
Those steps should fix your problem. It took me awhile to get it set right, and asking questions out here to get it solved. Worked like a champ ever since. No need to shave anything, it is simply a "drag" issue when you apple the throttle.
Hope this helps.
Last edited by lilstewie; 03-24-2011 at 04:56 PM. Reason: chagne "drake" to "drag"
#1574
There are tons of parts available. Check various online shops and even EBay. Why would you restrict yourself to just the HB factory site?
