Serpent S811-T Truggy...
#1667
Had some track time was have some issues with rear traction track was very loose.
Oils were 7,10,3 changed to 7,5,3 moved rear link up added from droop added 2.7 sway and decrease front height to 36 front 38 rear.
This helped but had some push coming into tight turns adjusted brakes with more bit in the rear to swing its ass but was wondering if you guys had some pointers increasing rear traction and limiting its push
#1668
try 7/10/4
#1669
#1670
ok guys, need your help. I'm still not 100% happy on how the serpent truggy feels. I haven't ran it that much and i haven't played with any particular setups. Since it's been please, please send me a setup sheet i can maybe follow. It turns O.K.A.Y. I would like to get more steering (i know it's a truggy, but i like TONS of steering) and i would like for my tail to slide a little more. so, if someone has this setup, please let me know..
thx
thx
#1671
I'm running pretty much the Charles setup with 35 oil all around 8 hole 1.3 drilled, 5-7-3 and lowered rear link to the lowest inner hole on the tower. Stock swaybars. You could try 4up in the rear front holder and 6 in the rear of the hinge pin holder. That loosened up the rear of the buggy
Ok will give that a whirl what shock springs are you running white seems to bouncy. Where do I find the Charles setup
#1672
thx
thx
#1674
thx
thx
#1676
Be careful, you dont want to upset the Nitro gods they talk very closely to the OS gods. When the gods are upset strange things happen....
See you on Sat
I have an excell spreadsheet that has what parts are interchangeable and what parts are specific to bug, trug and E bug. Gimme a min and Ill post up a google docs version.
Heres the link. Let me know if you have any issues with it.
https://spreadsheets.google.com/spre...FTR2c&hl=en_US
See you on Sat
this part says for 811T and 811E. Amain says this same part is for 811 and 811E (which makes sense). which is correct?
#1677
Make sure it isn,t a loose servo saver
#1679
they are for the buggys but.. the only diffrance is they have a lower roll center then the truggy ones. billy should be working on 10 truggy ones.
