Serpent S811-T Truggy...
#922
Let me try to explain via text. You need this piece below (from v1 kit).
http://www.amainhobbies.com/product_...ake-Slider-Set
and you need the brake slider that comes in the cobra-T kit.
If you look at both pieces, they both have fittings to fit into the servo horn of the throttle. What i did was, i cut the brake slider's fitting completely off that goes into the servo horn. I used the SER600120 (link above) as is without any modification. This part is used for the throttle. I slid the SER600120 part into the servo horn. I got a screw that would fit perfectly from the brake slider to the throttle slider. I bored the brake slide out just a little to give it a little independent motion from the throttle slider.
looking from the front on the car, the pieces would fit as follows.
throttle slider set SER600120 + servo horn + modified brake slider (cobra T kit) + screw
hope i explained clear enough.
#923
R/C Tech Elite Member
i can send pics later today when i get home.
Thanks again!
#924
My Rear Hub Bearing blew up after 2 weekends, i used an axial axa1243 to get me by all that was available for the day before club racing.
Other than that no issues for me but 2 other guys are having issues when applying full brakes the rear diffs seem to be doing some sort of grinding, possibly spacing issues as the truck have been broken in maybe the gaps are to big?
#927
take your time doing the radio tray
add a 2.7 rear sway bar and a hard servo saver spring billy nats set up with 3 1.3 holes in each 1.2 piston and its on
#930
I would echo nothing as well. I'm not sure on the 2.7 sway bar, I have one because I was told it helped the truck, but in the month I've owned the sway bar I haven't pulled it or the 2.3 out of it's bag yet. I do though whole heartily feel the stiff servo saver spring is needed. I believe setup from person to person will vary quite a bit, as I've raced the truck on 3 different tracks and feel optimal setup at every track was different from the last, so maybe I haven't been on a track yet that the 2.7 or 2.3 bar would benefit me. Worse case scenario you buy the truck, the 4 dollar stiff spring and maybe a couple sway bars. Truck durability is out of this world. I'm sure there is an isolated incident of someone breaking the truck, but if my memory serves me correctly, in all 62 pages there hasn't been a report of anything breaking. I know I sent jkirkwood's truck over a 40 foot triple for a 30 minute main lap after lap with zero issues. To top it off, the truck is fast as hell, that same race it was one of two people to be in the 20 second lap time range (20.5) out of 71 entries, the other being the track owner that had quite a bit of fuel on the track. Three races, three podiums and I'm not that much of a wheelmen, the truck is that good.
