Serpent S811-T Truggy...
#3168
thanks for the advice....should i rotate the links 180 toward the knuckle or toward the spring?
I have had to take out my radio tray a few times, and I notice the screws are not as snug as it used to be. Do you guys have any tricks to keep a good bite when screwing into plastic. I do not overtighten, but maybe I could put a drop of CA glue in before I put screws in. Does this work?
#3169
The easiest way and most precise way I've found to adjust the brakes is to take the tank out and use an open end 5.5mm wrench and adjust the front pad screws evenly. You might have to tighten or loosen them depending on what you want. After you get it set you won't have to mess with it for a long time.
Thanks.
#3170
#3171
I'm just giving my Serpent followers a heads up. I putting a 811T with a slew of upgrades for sell in the sale forum tomorrow when I take some pics.
#3172
ok, i will be ready to see what you have.
#3173
#3174
#3175
Thanks for the tip. I just ordered some buku stuff earlier today, I am sure it will work great.
#3176
I'm curious to see how long your antenna last sticking out of there. Most racers just heat the tube up and bend it over so it stays under the body.
Your going to love the Bonito. I run the CRE Bonito and it's really nice smooth engine. Super easy to tune also when you listen to Neals advice
I have 2 buku clutches here I'm installing in my Serpents tomorrow. Can't wait to give them a try.
#3177
For the lower shock mount set screws, I also went to the longer set screw which helped immensely. 5mm long in front and 6mm in rear.
#3180
my local shop doesn't really carry hump backs. It's easier to get stick packs. that's why i am asking for any mods you guys are doing.
