Ask Aaron Waldron
#602
Chris -
Front:
toe- 0
Ride Height - Arms level
Caster - Stock
camber- 0
Shocks - 25 weight, 57 piston, .50 internal limiter, Silver Spring
Spindle location - Top
Bell Crank - Outside
1 washer under the front ball stud
0 washers under Spindle Ball stud
Shock Locations 2 - middle
Camber link 2 - b
Arms short
tries- 7206 prescrubbed Silver
Rear-
2 degrees anti-squat ( just to make it jump that stupid double better)
Bones above level
Camber + 1/2
hubs - center
Rear Shocks- 27.5, 55 piston, internal Limitier- .90, Red Spring
Camber Link- 1 B
Shock Position - 3 middle
Arms short
tires-
Silver ifmars in the morning
Red Taper pins when the track was swept ( still had too much side bite )
Front:
toe- 0
Caster - Stock
camber- 0
Camber link 2 - b
Arms short
Rear-
Bones above level
Camber + 1/2
hubs - center
Camber Link- 1 B
Arms short
tires-
#603
Brian,
I was running Aaron's XXX BK1 setup, but knowing me, I had to make changes. I'm never happy knowing that a setup is good the first time out. It will be the death of me someday. I ran this all weekend...
Front:
40wt oil
55 piston
no limiter
2 on tower, middle on arm
3-B with no washer
1 deg. of toe
1 deg. of camber
Rear:
32.5wt oil
56 piston
no limiter and unthread 3 turns
2 on tower and outside on arm
2-A link
1 deg. of antisquat
1 deg. of camber
I ran a different tire for every main. Worn out X-2's in the first (not enough traction).... Fresh Ifmars in the second (traction rolled)....Holeshots in the third (just enough to take the win) I hope to see you again in Tacoma!
-chris
Front:
40wt oil
55 piston
no limiter
3-B with no washer
1 deg. of toe
1 deg. of camber
Rear:
32.5wt oil
56 piston
2-A link
1 deg. of antisquat
1 deg. of camber
-chris
#604
Ask Aaron Waldron
I got a question for you. Why aren't you keeping up with your moderating or at least your thread. What did they do to you out there in Shweeden? Did you loose all your moderating and question answering power? Talk to me Man!
Just kidding...how was the trip?
#605
Trip was freeeeeee! I'm running for Jammin'/Ofna now..I get my car in a few weeks :-)
And it was the most fun I've ever had..oh man.
TSB -
1. Inside will give you more, and usually smoother, steering.
2. I'm pretty sure it's the spindle that will give you bump-in, and keep the car stable when jumping and going through bumps.
3. It will help stop the ballstud from breaking. And it makes it easier to get out if it does break.
4 and 5. Not sure what raising the spindle does..no one ever does it. Down is the best everywhere.
6. Changing pistons changes "pack", which is how the shock reacts to short and sudden compressions.
TSB -
#606
AW
You going 1/8 scale now??
Dave mAC
Dave mAC
#608
Pballkid I wont ask, how you got that name lollo
everybody likes a little a$$, but nobody likes a smart a$$!! LOLO
It just seemed odd to me that AW would get a full ride in 1/8 since I didnt know he ever raced them, and was hinting him to elobarate how it came about. Its all good
Later
Dmac
Later
Dmac
#609
Sponserships come around for many reason's. One is knowing the right people. As for driving an 1/8th scale. Aaron is an acomplished 10th scale gas truck driver. If you can drive that fast an 1/8th scale is easy! The thing about 1/8th scale is that it is expensive!
Congrats Aaron. Now just make sure drivng that new 1/8th scale BUGGY (j/k inside joke ) does not take away from your ability to drive 10th scale. 8th scale can be so easy to drive it will make you stupid! LOL
#610
mf2-bk2
what is your standard set ups for a rough loamy track on the mf2 and bk2
#611
what would cause a T3 to scweak will you were mving slowly but not fast
#613
WO....somebody actually asked ME a question. I must be cool or something. Eehh, no, I am not Chris Bridgewater....I wish! I am chris Woods, of A-main raceway in Vancouvar. But I really don't mind if you want to call me Chris Bridgewater. I don't mind being known as a national champion....
#614
Cruz out to Shorters!!!
I can't wait to get my Jammin Buggy!!!!!!!!!!!!
#615
I will be running the brand new Jammin'/OFNA buggy, and should be getting my kit sometime soon. Jay Halsey is the team manager and he's a total kick, I think it's gonna be a lot of fun.
Nothing will take away from my responsbilities with Losi and doing my best to win races for them.
bigl - I've only run on loamy tracks with my Gen II cars once, and I can't say that they were set up the best they could have possibly been.
I'd start with the stock setups for both and start making changes to suit your driving style. Both kit-included setups were aimed at a neutrally-balanced car for all kinds of track surfaces.
AE basher - Your slipper or diff could be slipping, or your gear mesh might be too tight (which may have ruined the pinion and/or spur gears).
notch - I don't have a week off for almost another month..but I'll be there soon.
