NEW AGAMA A8 BUGGGY
#916
I liked the towers anodised black, it gave a spark of luxus to the buggy
wonder why they didn't hold on to that..?
#917
#919
#922
Wiregrass Nationals
Ran the Agama for the first time this past weekend.Gene's set up was dialed when the track was smooth on Friday(my only change to his set-up is that I run 8 hole front shock pistons 6x#54 2x#55.As the track started to blow out I worked on the set-up ended FRONT/30wt oil upper shock center hole lower shock outer hole 2.5mm bar 5k in the diff -2 neg camber.REAR/25wt oil upper shock center hole lower shock outer hole 2.7mm bar 3k in the diff.Center diff was 3k -2 neg camber.Also I took out about 2mm droop and it helped the buggy to stay real stable in the big ruts when others were traction rolling in them.The car is much easier to drive fast compared to my Losi I've been driving for two years.I love the gearing when the track rough you don't all that much room to clear the double and triples.Also I really think it helps with fuel mileage.
#924
That picture is from the Germany car show back in Feb before the car was in production. They also had one there with all orange anodized parts. They were just prototypes. The parts are now gunmetal because that is nuetral and goes with any paint scheme.
#925
took the my car out for its first run today. it was the engines first run on the ground.
the car just turns. going as slow as the car does with a brand new engine and i was still getting it on two wheels.
GREAT!!!
can't wait to race the car on sunday.
by the way(probably not the place to ask but) what is the minimun no. of tanks fuel to start race tuning.
GREAT!!!
#926
Everywhere Ive checked is "out of stock"...even Terribles RC..Whom were quoted earlier in thread as "having every part on the wall"...
Thanks..
#928
All the parts and more kits are supposed to be in stock Sep 1st.
#929
Hi I made one, but is on Spanish so if you want it pls send me an email to : [email protected]
Best Regards!
Daniel Ornelas
Vp Pro Mexico
Agama Mexico
Go Engines
Best Regards!
Daniel Ornelas
Vp Pro Mexico
Agama Mexico
Go Engines
#930
Has anyone tried the option overdrive diff yet?? We have them but I have not had the chance to try it out.
