NEW AGAMA A8 BUGGGY
#6707
With your servo and battery being forward it will for sure be loose in the rear on 99% of tracks here in the states. This may not be all of your problem but it's hard to drive and will just plant the front and the rear comes around.
I agree that the stocker setup may not be the best. Try to start middle on everything and go more a long the lines of what was just posted a few post back and then work from there.
AB
AB
#6708
Agama Build
A few pages back a video was posted of the Agama that the young kid got for Christmas. He is a local in my area and he and his dad have really listened well and have put in a lot of time in the last 3-4 months since starting. Luke Sutton is his name and he is 11 years old. I have the chance to work with him and am spending a couple hours a night teaching him to build his own kit. I have always wanted to start with a young kid and help him grow. Luke, John, and I have a goal of top 20-30 at the Alabama Manufacturer Shootout in the Sportsman Buggy class. I posted some pics last night on facebook and many of you guys encouraged him, he was super pumped! Here is a few pics of the start of his Agama A8 build!
#6709
alan, jason, gene, heres a question
what do you guys think about the r4 chassis, i tend to like my buggy on the safer side and nice and planted in the rear. does the longer chassis have a more foward weight bias, does that reduce the rear traction compared to the stocker.
#6710
Guest
You are lucky Luke, try to absorb everything Alan teaches you and you will have a big head start on most young racers.
#6711
Guest
These 2 things seem to counter each other and makes the R4 have the same traction as stock, but better in the bumps and more stable over all. But that is just my opionion. I have had some locals try the R4 and say it made the car undriveable. But many of those who drove my buggy liked it. It does take a different setup since the weight bias is different. But me, Brandam, and Kort are all using the R4 chassis and like it. Smolnik is still using the stock chassis. It is just something that everyone needs to experiment with to see if they like it.
#6712
#6713
I think the R4 chassis is a good all around tunning option for the Agama buggy. The A8 has very good corner speed and steering so going to a longer chassis, which in theory would take some steering away, is not really going to be affected that much. The R4 chassis will make the car safer in that it will allow the car to cover more ground area which will make it more stable. It's really going to help on the rougher tracks and I have not noticed any rear traction loss with it. I have only limited time on the stock chassis and I feel it makes the car more agile and gives the car more steering. Of the two I like the R4 better so that is what I run just about everywhere.
This past weekend at the Warehouse race would have been a good situation for the stock chassis because the track was small and tight but still I had plenty of steering and traction with R4 so I stayed with it.
As Gene said the R4 chasis will give the car more forward weight bias because the rear has been extended which moves everything else forward as weight is concerned. And also as Gene said "It is just something that everyone needs to experiment with to see if they like it."
#6714
Hey guys,
the cars seem to be getting better and better each race. Team Agama will be very strong this year and with all of us working together, the A8 will just continue to get faster, I'm positive the car is capable of even more : ) I had a great time this past weekend at The Warehouse, Agama and Arrow Engines had an awesome showing at the race. Jason Branham had a great first outing with the new Beta tires and they look to be a big threat in the tire industry. I posted my set-up below, I seem to stay pretty close to this everywhere I go
Warehouse Raceway set-up
Diffs -4000 F, 5000 C, 2000R
Shocks - 1.3x8 hole tapered pistons (in all 4 shocks) (+2mm shock caps)
Shock oil - 40 in front, 35 in rear
Springs - Grey
Long shock ends
Middle hole on front tower and outter hole on arm
Middle hole on rear tower and outter hole on arm
12 degree caster blocks (stock).
+1 hubs in rear and stock in front
Inner hole on front caster block, middle on front tower.
Middle hole on rear upright, middle hole on tower.
Wheelbase: centered
Inserts:
front - 0 front rear, 0 front front
rear - 0 rear front, 0 rear rear
Jconcepts Punisher wing
2.3 front sway bar, 2.4 rear sway bar
battery in rear
Standard chassis
long ackerman plate
Droop:
front - 108mm
rear - 130mm
ride height:
F- 29mm
R- 28 mm
Jconcepts Punisher body
break bias - 40% front, 60% rear
Corey Johnson
Springs - Grey
Long shock ends
Wheelbase: centered
Inserts:
battery in rear
Standard chassis
long ackerman plate
Droop:
front - 108mm
rear - 130mm
ride height:
F- 29mm
R- 28 mm
Corey Johnson
#6716
For those of us burdened with running super long antennas (like Ko Propo), has anyone found a good way to route them?
I gave up having an antenna tube stick up out of the body... between over-rambunctious spotters and the sheer fact wrecking on the lid cracks the tube, I am keeping it inside. I shaped the antenna tube to follow the contour of the front window, which seems to work okay. Sometimes when I'm working, though, I'll end up breaking/cracking/bending it.
Was wondering if Agamanation had any better solutions.
#6717
what RX is it? why cant you pull most of the antenna into the box and then use a short piece of tube? I use airtronics stuff and the antenna wires are pretty short but I still just use about 2 inches of tube and cap it off with the antenna wire just dangling about 15MM's off the top. It fits good under my lid and I have never had any issues with glitches or failures.
#6718
408S and 407S are the ones I use. I tried looping about half the antenna in the box but it seemed like I may have been having servo glitch issues (possibly Rx batt going dead, who knows) that day. Went back to older way and seemed fine. Probably worth a shot to try again; thought there may have been a super slick way people were holding out on.
Airtronics already come with super short antennas to begin with. Pretty jealous.
I saw a guy who ripped his antenna wire right off the Rx board on an older Futuba Spread Spectrum, then proceeded to run a whole race with no glitching. I was impressed.
