NEW AGAMA A8 BUGGGY
#1501
I just re-used my shock oil when I was testing setups, I'd try something different, run a tank, then change again and just pour the oil back into the bottle. I tried pretty much everything from 1.2-1.5 pistons and from 20-50 wt oils. Now I know what works and what doesn't. The best I could find so far is what I'm running now, 1.3x 8 hole front and rear, 32 1/2-40 wt in the front, 27 1/2- 35 wt rear, depending on temperature and track conditions.
I am going to test some different spring combo's this weekend as well as some different pistons. It could always be better!
#1502
yup, pretty much the same here, run it for a tank and try another... 8x1.3 30AE front 25AE rear, blue rear springs and red fronts.... I've tried a few other combinations but always come back to this setup, shocks on my car are pretty much dialed. Diffs i still mess with depending on the surface, but thats about it.
Try those front kickup changes this weekend, I think you'll like them as much as the rear link
#1503
#1504
Qando but the track is full of holes six softer or harder than oil?
#1505
whats the best diff shock setup to start with will be running on large dirt track?
#1507
Also can someone post a photo of a drilled 8x1.3 piston...I haven't done it so far, and it should be good to see the final result....
thanks
And only closed cell foam work in the shock caps?
thanks
#1508
Diffs - I usually run 5/7/3 or 7/7/4 depending on how much steering I need.
I cut up some old school tire foams (I think they were panther greys), the foam is there to support the bladder, so harder foam = more rebound, you can experiment
#1510
I started building my 'Gama last nite, been 12 months since I've worked on a car, and wow - the diffs we pretty easy to build. I love the way the ring gear sits nice and snug over the diff case, no sliding around etc, so the gaskets all line up nice, and don't move around.
I've gone 5 5 3 for now, will test that out.
Tonight I will move on the shocks - but I have just two questions :
1) are the standard 6 hole pistons ok, or should I order something different?
I know my LHS stocks Hyper 9 parts, so they should have some 17mm jobs.
2) Will the standard included oil and springs be ok, or should I change them out too? I usually run 1/2 rebound in my shocks, so I will stick to that.
All in , very nice
All in , very nice
#1511
All in , very nice
All in , very nice
#1512
I'm not Gene but the mod is very easy to do...
drill the cap with 1-2mm bit (I used 3mm because thats the smallest I had) but it doesnt really matter as long as a small amount of air can move in and out. And I use pieces of foam from spare tire inserts lying around.
pics attached:
pics attached:
#1514
thanks for your input!
#1515
pics attached:
pics attached:
So should be fine if i use a 1.5mm drill bit????
