Serpent 811 Cobra Buggy
#7096
#7097
Hey guys I have built the serpent 811 but I am having trouble with the radio tray. I am not getting any brakes the linkage does not seem to push the brake rod back what am I missing..??? Thanks in advance for any help!
#7099
If its the V2 radiotray its not supposed to push the rods back, its supposed to pull them forwards.
#7100
thank you very much!!
#7101
#7102
8 hole conical piston maybe a stupid question but is the tamper face installed going on the up travel of down travel.
#7103
Big thanks to Absolute Hobbies. I made an order Wednesday evening and got my parts in the mail a few minutes ago. Thanks for the decals also.
#7104
#7105
So you will have a smoother compression when she absorbs correct. I bought some 8 1.3 con pistons having a lot of chassis slab bought some purple spring for front and rear plan to try 37.5wt front and 35WT rear.
#7106
Go thing I askedcause I had the tamper installed upwards meaning looking into the shock body your see the tamper portion. Will make the change.
#7108
look at the pistons guys there only one way the washer gose in
#7109
So the tampered side will face upwards. I had it correct you will get the smoothness on the damper. I bought some pistons off ebay it doesn't have a grove for the washer. So if your looking into the shock the tampered face will face you.
#7110
