losi 2.0 shock mod ?
#16
I can also build them for anyone who may not feel easy about doing it. It's $10 per set on new shocks(includes orings and oil if needed). Shocks come back ready to go.
On used Shocks it's $10 plus parts(includes 8 o-rings for the mod). In some cases new bladders are needed.
Post in the Speed shop thread or email me @ [email protected]
#19
#21
I took some pics ,but they were blurry.
heres ther skinny. well at least what I did. I used a .065 drill or 1/16" drilled a hole in the top of the shock cap.Make sure you drill on the inside of the circle(look inside shock cap to see.)I got pieces of on road tire foam from a Losi team driver who cuts them onto 4 little discs to support the bladder. I wil try again tonight when I maybe get to work on my truggy.Too many paintjobs to do to play r/c mechanic. I will tell you though the mod is awesome and makes the ride ht very consistnt when the chassis and the shocks and all get heat soaked or warm I guess I have not started taking shock temps so... I did try a softer foam before the on road tire,and it did work,but you do need to support the bladder so you may want to mess around with different densities even perhaps. I went what was proven to work and/or help in the end. I am curious bout shock temps now hmmmmmmm nevermind
#22
I have also done this shock cap mod to my shocks with great results but with the o rings and not the tire foams. I've read that alot of guys are useing tire foams of different densities too and wondered if there would be any benifits to this. I guess I could do up one set with foams and keep the set with the o rings and see if there is any difference.
#24
Like someone said earlier this was posted in one of the magazines but I can't remember which one. Basically just a tiny hole straight down beside the mounting hole. If you look at the inside of the shock cap there is a machined ring inside there. This hole will end up on the inside of the ring (near the center.) Then two of the shock seal o-rings glued together and then glued to the center of the shock cap on the inside, just be sure the new hole is not covered by the o-rings when they are glued to the shock cap.
If I knew which mag it was i'd scan the quick little article and post the picture.
#25
Ok I found the article. The new hole isn't quite near the center of the center ring like I thought. It's still inside the machined ring inside the shock cap but the hole is towards the outer edge of the ring. They say to use a #56 drill bit.
RC-Car Magazine June 2009 Volume 12 No. 6 back on page 96 and 97.
If no one has posted pics by the time I get home from work tonight I'll scan this article and post it up.
#26
#30
prety much what I did minus the o rings thanks for the pics
