losi 2.0 shock mod ?
#61
Is this mod mainly for the front shocks or does it also help the rear shocks too?
#62
has anyone tried the o-ring method and does it work as well as the foam method? also could the shock mod be done to plastic shock tops because i have plastic shock tops at the bak and metal ones at the front?
#63
Lewis: the o-ring method works fine just a little harder to deal with building the shocks. the new foam from losi is pre-cut and sticky on one side to make it easyer to use. as far as i know you could mod the plastic caps.
#64
what do you mean by it being harder to build the shocks? also saying the foams being sticky on one side what benefit does it have?
