8T 2.0
Has anyone tried the pro-line high down-force wing? I was thinking about getting one and wanted to know if you guys had experience with it. Thanks
I'll check them out then.
If you think other wings "perform better" please tell us your back to back test results and why the VP pro wing is better.
I just wanted a different look but the losi wing is pretty tough. I don't want to buy a different one if it's going to break easily.
What exactly are you upgrading from the stock losi's? About the only acceptable answer is "appearance" and of course thats only relative to your opinion.
I personally like the looks of the losi wing.
all i have to say is wow......we should take a pole on who thinks there should only be ADULTS on this site
thanks man wat about shock oil weights wat is factory and wat are most running.also on the traction bar i guess that is wat it is called .the little bar on front and back mine say 23.i remmeber reading in here factory was wrong on back if so which do i need to install thanks
