8T 2.0
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
hey guys i am building up a second clutch and i have some springs that i cant tell if they are the black or greens. If i hold them next to a light source i get a greenish shimmer off of them. but in low light they look kinda black. Any ideas on which ones they are guys?
![weird](https://www.rctech.net/forum/classic_images/smilies/weird.gif)
![Laughing](https://www.rctech.net/forum/classic_images/smilies/laugh2.gif)
Hey guys which brand rear hubs seems to be the best for the money? I remember when I had my last t 2.0 that lots of people were complaining about the rear hub bearings being too small and blowing out often.
I was looking at putting bigger bearings in some stockers or the KH ones or the Losi aluminum ones?
![Nodding](https://www.rctech.net/forum/classic_images/smilies/nod.gif)
I've tried both the Losi and the KH rear hubs and hands down the KH hubs are better. Racing on a track with big jumps, I had to replace the outer bearings on the Losi hubs every round. Now with the KH hubs, I get a normal maintainence interval out of the bearings. Pony up the $$ just for reliability sake.
The KHZ hubs are well worth it. I personally run Losi aluminum hubs that have been modded to run the 8x16mm bearings. Same bearings the KHZ hubs are designed to use. They aren't cheap, but if you want a reliable bearing setup they're pretty much a must have.
search J-DUB on this site.....this is THE answer for your rear hub issues....
Thanks guys for the input. Sounds like I will go with the KH hubs.....
