8T 2.0
#8716
#8717
#8719
Saw your post yesterday and checked mine this AM. I have the adjustable F & R plates. The front dogbones are in the cups with maybe 1/8" of the slot left on the outside. Droop 110mm.
The rear dogbones are in about half way. Droop 129mm, toe 3*.
I have never had them come out.
Are you measuring droop from shock bolt to shock bolt, wheels off the ground? Just trying to help you find a solution!
#8720
Quick question guys. After installing lightweight out-drives and aluminum hubs i noticed that with 129mm of droop the rear dogbone on the radio tray side was very close to failing out of the out-drive at full extension. I ran the truck two laps and the dogbone popped out on both laps, is there a fix or is there something i may have assembled incorrectly?
#8721
Man I don't get all of these drive shaft issues that I keep hearing recently. Has anyone that's had the issue checked the length of the drive shafts in question against one without the issue. I'm wondering if there wasn't a run of bad shafts recently that are too short. Anyway the pictures bigjayjay1 requested will help us figure the issue out.
#8722
#8724
#8728
Those scratches on the outdrive ,is that when the axel came out? maybe you had a rock stuck in there. I had that happen once. Fine ever since.
#8730
it came from the dog bone coming out. i ran the truck on the track for two laps total and it popped out when landing off a jump the same jump actually both times.
