8T 2.0
Old 06-14-2010 | 07:23 AM
  #7756
token's Avatar
Just wanted to rave about the Aluminum Inclined King Pin Spindle/12*Carrier LOSA1728, And the V2 setup with cut links. DIALED.......On Power and Off power was improved. On power steering is no joke on a well watered track.
I think it compliments the V2 setup perfectly. Now I just need to pick up the King Head rear hub, cause these bearings are killing me.
token is offline
Old 06-14-2010 | 09:49 AM
  #7757
reggie l.'s Avatar
i cracked and got me some also
reggie l. is offline
Old 06-14-2010 | 10:21 AM
  #7758
Trevor Williams's Avatar
R/C Tech Elite Member
I just got the v2 rear tower....is anything else needed to use this?
also.......does the Ballistic nimh rx pack fit in Losi box?? I am used to Protek LI-fe speed and power in my K cars, but they would'nt fit in the losi box, im not hacking it up either.........what are you guys running for rx packs............Im open to suggestions, looking at the Ballistic nimh & Losi lipo and Losi regulator with switch right now.
will this fit properly without modification?
http://www.amainhobbies.com/product_...-Losi-8ight-20
Trevor Williams is offline
Old 06-14-2010 | 11:22 AM
  #7759
Integra's Avatar
i would personally go with my 5$ ebay specials.
Integra is offline
Old 06-14-2010 | 11:58 AM
  #7760
JAMMINKRAZY's Avatar
The ballistic pack will fit without the foam in and using the hump lid. The losi lipo fits perfectly with the foam and flat lid. The ballistic pack is also very heavy. I used to run AA packs like the ballistic one, and they worked well but nothing like the lipo does.
JAMMINKRAZY is offline
Old 06-14-2010 | 12:13 PM
  #7761
G_WORD's Avatar
what are some ways to get more off power steering . im useing the 10* kingpin spindal and carrers.
G_WORD is offline
Old 06-14-2010 | 12:19 PM
  #7762
Short ackerman, shorter rear camber links, thinner rear sway bar. Same 3 things I have recommended to others in this thread.
Old 06-14-2010 | 01:01 PM
  #7763
token's Avatar
Originally Posted by JAMMINKRAZY
The losi lipo fits perfectly with the foam and flat lid. :
I cant get that dam flat lid on it with the stock foam. Are you using stock foam?
Maybe I will try again
token is offline
Old 06-14-2010 | 01:13 PM
  #7764
Frank L's Avatar
Guys I am telling you the losi lipo why fix it if it aint broken??
Frank L is offline
Old 06-14-2010 | 01:41 PM
  #7765
TIX's Avatar
TIX
lower your front ride height a little try 37-38mm
TIX is offline
Old 06-14-2010 | 01:48 PM
  #7766
Yep stock foam. Connector is outside the box. I have a hole drilled in the side of the box so I can easily pull the connector through to get the battery out for charging. It's too damn hard to get it through the stock hole when the tray is in the car. I'll try to get some pics of how I have it setup.
Old 06-14-2010 | 01:59 PM
  #7767
Here's a pic. The pic isn't too great, but you can see how everything it routed.
Old 06-14-2010 | 03:28 PM
  #7768
losi_racer's Avatar
I run the yeah racing lipos, they fit perfect with a flat lid and connector inside the box
my dad had two fail on him. plus yeah racing lipos range from 20-40 bucks, matters where you get them.
losi_racer is offline
Old 06-14-2010 | 04:31 PM
  #7769
NuthinFancy91's Avatar
NuthinFancy91 is offline
Old 06-14-2010 | 05:17 PM
  #7770
Bman's 3XNT's Avatar
New V2 rear shock tower, Short rear links, No front swaybar and 5k front diff oil. I have no problem with slow speed steering now...........
Bman's 3XNT is offline
