8T 2.0
Old 03-10-2010 | 06:20 PM
  #6136
trackstarlosi's Avatar
Originally Posted by Mikey-B
do they have " inclinded spindles and castor blocks" for the truggy??........and what would they improve?
not sure if they are for sale yet. they probably just increase handling in someway
trackstarlosi is offline
Old 03-10-2010 | 06:24 PM
  #6137
8&stuff's Avatar
kingpin blocks&spindles due this month and next. helps steering
http://www.losi.com/Products/Feature...rodId=LOSA1728
8&stuff is offline
Old 03-10-2010 | 06:25 PM
  #6138
Grimlock212's Avatar
Originally Posted by JAMMINKRAZY
The buggy ones will fit the truggy. I couldn't tell ya what they would do though. I haven't tried em yet. Not sure they are even available to the public yet.
I think the will be available late-April. They should change camber angles and from what I've read are far more stable on high speed tracks.
Grimlock212 is offline
Old 03-10-2010 | 06:27 PM
  #6139
Actually they now says these will be available late April. http://www.horizonhobby.com/Products...rodID=LOSA1728
Old 03-10-2010 | 06:50 PM
  #6140
Mikey-B's Avatar
thanks for the info
Mikey-B is offline
Old 03-11-2010 | 05:21 AM
  #6141
offroad racer's Avatar
Default Losi's offroad tire gluing kit
Hey guys I got an offroad tire gluing kit from Losi because the preglued tires that came with the RTR were starting to come off. I haven't used it yet because there is a plastic thing sort of like a wick taped to the bottle. Could you please tell me what to do with that. Thanks
offroad racer is offline
Old 03-11-2010 | 05:44 AM
  #6142
Frank L's Avatar
Sinew like a glue bottle to me. Cut 2 inches off f the plastic wick and stick it n the tip of the glue bottle. That's the applicator. Just jus small drops of glue and then press and hold the tire after glueing. You also need a set of mounting bands or rubber bands to put over the tires after glued to hold them while the glue completly dries.
Frank L is offline
Old 03-11-2010 | 06:19 AM
  #6143
tc5 man's Avatar
why doesnt, losi offer them as a plastic set?
tc5 man is offline
Old 03-11-2010 | 06:52 AM
  #6144
Integra's Avatar
the losi kit comes with bands i think.
Tc5 man....then losi wouldn't make as much $$..sad but true.
Integra is offline
Old 03-11-2010 | 08:35 AM
  #6145
losi sell just the glue LOSA7880 or the tire gluing kit LOSA7884
geejay is offline
Old 03-11-2010 | 09:59 AM
  #6146
tc5 man's Avatar
i guess $100 isnt that bad for both alum pieces. maybe i try it out
tc5 man is offline
Old 03-11-2010 | 03:19 PM
  #6147
G_WORD's Avatar
last year billy fisher was at a local track and i noticed he was not useing a front swaybar ....anybody doing the same
G_WORD is offline
Old 03-11-2010 | 03:30 PM
  #6148
JAMMINKRAZY's Avatar
Removing the front sway bar will provide more chassis roll and weight transfer when cornering. You will gain a bit of steering, but loose stability in high speed corners and switch-backs where you need to go right to left quickly. It can also cause traction rolls because of the weight transfer. Unless you really need a bit more steering and have tried everything else, I would leave the bar on. There may be other reasons to remove it, but the above is the one I have heard/experienced.
JAMMINKRAZY is offline
Old 03-11-2010 | 04:18 PM
  #6149
tc5 man's Avatar
yea but what about removing the, front swaybar on a rough rutty track? whould that do, the same thing or help more?
tc5 man is offline
Old 03-11-2010 | 04:30 PM
  #6150
Mikey-B's Avatar
i am currently running alum. hub carriers.....are the new carriers inclined also?......or is it just the spindle?
Mikey-B is offline
