8T 2.0
#1772
#1773
#1774
The problem comes from the bearing being too small. The best option is to mod it/ have it modded to fit the larger 8x16x5 bearings. If you want to get it modded PM J-DUB. You can just use better bearings, and extend the life somewhat, but in the end they are still going to fail prematurely.
#1775
#1779
I have the 2.0 buggy and 2.0T, I'm putting the adjustable hinge pin braces on the cars, and wanted to know the correct inserts to use. Either the 0 or .5 or 1's
Looking at the set up sheet Losi mentions 20 degree caster. Does this mean I should set the front up at +2?
#1780
Alrighty then, thats exactly wat i thought.
Integra- I think u deserve alot of Thanks for all the people and stuff u have helped on this site. every since i have been on this site...i have saw ur name just about everywhere either giving advice...or telling someone off.
lol but yea ur a gr8 attribute to rc-tech, just wanted to throw that out there!~
#1781
#1782
do you have any slack between your hubs, you should have a little if not they will wear quick. i shimmed the slack out of my lst once and rear wheel bearing fell apart after 2 heats in main. just a thought may not be it, i put a set of avids in and raced my 4th weekend and my bearings are still ok! maybe just lucky
#1783
on my mugens, very little slop. and they never went bad on me. maybe because the rear hubs are alum.
#1784
I had 1x bearing blow out and replaced it and then regreased the others last week for racing yesterday and they were fine and I had another win in the main..2x club meets in a row
only changes I made were a 3x degree rear toe plate and shock oil to losi 40 in front and 35 rear and seemed to settle the truck a little more and boy was it awesome to drive...I am in love
