8T 2.0
Old 03-25-2009 | 03:23 PM
  #1606
JAMMINKRAZY's Avatar
Originally Posted by bphil49
Do we need to put o-rings under the radio tray like the 1.0?
nope
JAMMINKRAZY is offline
Old 03-25-2009 | 03:28 PM
  #1607
bphil49 is offline
Old 03-25-2009 | 03:30 PM
  #1608
rhino420
Guest
Posts: n/a
woooo whoooo just got my 2.0 !!! cant wait to get this thing on the track its been two weeks since ive raced and im feening like a druggie haha !!
tonight im gonna just go through it and make sure all the bolts are tight and rebuild the diffs and rebuild the shocks what you shock weight are you guys running in them ? any other things i need to be aware of ?
Old 03-25-2009 | 03:49 PM
  #1609
rookie-00's Avatar
I CHANGE THE SERVO SAVER AND THE STEERING IS SOW HARD...
rookie-00 is offline
Old 03-25-2009 | 04:11 PM
  #1610
this is my truggy if it works...lmbo first post for me...
she'll get bout thirteen a tank... no joke!!!
rb.21w7slll
3pk w/dsm hrs
jr servos(9100series)
lipo bat.
J-DUD hubs f/r(i'll pm u sumtime soon, by the way i luv'em)
thanks for lookin
TOPS
TOPS is offline
Old 03-25-2009 | 04:30 PM
  #1611
Originally Posted by Stanton
Aaron,
There was a bad batch of bearings. But, you also need to take out the side play in the rear axels. Use LOSB3951 13mm shims. $3.00 You will like these. Mike Stanton
Wassup Mr. Stanton? How did the Cabin fever go for you? I was supposed to go but came down with Strep Throat the day before I was supposed to leave for the race
See you at Wenatchee?
SupermaxxRich is offline
Old 03-25-2009 | 05:17 PM
  #1612
J-DUB's Avatar
What did you use to mod those with?
cnc. i did a couple sets on the lathe but the cnc is so much nicer and cost effective
J-DUB is offline
Old 03-25-2009 | 05:25 PM
  #1613
ZERTA RACING's Avatar
how much dose it cost to get your hubs?
ZERTA RACING is offline
Old 03-25-2009 | 06:01 PM
  #1614
doubletap's Avatar
for a new to losi truggy are the ADJUSTABLE HINGE PINS holders(fr & RR), servo saver top(alum) and bearing holder/insert are necessary? and what else should get that is needed and doesn't come with the kit? thanks
doubletap is offline
Old 03-25-2009 | 06:27 PM
  #1615
The adjustable pin holders aren't nessicary. they are very nice and I run them on mine but not nessicary. The aluminum servo saver top is IMO nessicary. The bearing inserts are NOT nessicary on the 2.0 since you can just shim everything tight now.
Other nessicary things IMO are
Aluminum steering servo horn(I reccomend the losi one),
5-40x7/8" button head screws for the inner camber link screws,
5-40x5/8" cap head screws for the upper wing mount screws(upper screws that go through the tower towards the back of the truck),
1.0 truggy servo saver spring(2.0 spring works but has to be set very loose which can cause the nut to back off/not enough thread on the tube),
losi 2mm offset hubs only in the front(allow full steering without webbing in the wheels rubbing),
Modded rear hubs from J-DUB or the new KHZ hubs.
You can get away without those screws if you put loctight on the stock ones, but they are really too short. Same goes for the servo saver spring. You can use the 2.0 spring but you have to back it off pretty far for the servo saver to work. This can cause the nut to back off easily. you can use loctight to help keep it tight.
Old 03-25-2009 | 06:32 PM
  #1616
doubletap's Avatar
THANKS, I'll take a note of this.appreciate that.
Old 03-25-2009 | 06:56 PM
  #1617
mrramirez's Avatar
Hi guys I'm new to this forum.
Quick question guys, I was at my local track today, when my
Team Losi Servo Arm Insert stripped. I bought a new one, but the
tires still seem to lock on the side after a simple jump. I dont know what
else to buy or repair. I checked all the screws on my losi 8t 2.0
but everything seems ok. The mechanic said that the new servo arm
insert would solve the problem and but it did not. Thanks
mrramirez is offline
Old 03-25-2009 | 07:17 PM
  #1618
My bet is that it is still slipping. the stock losi steering servo horns are complete garbage. I would pick up an aluminum arm, preferably the losi arm.
Old 03-25-2009 | 07:31 PM
  #1619
lowblktaco's Avatar
Originally Posted by Integra
ah i see what your talkin about now....hrmm never though of it that way...but my shims are not being "thrashed" from the pin as the pin is nowhere near them.
I am confused about the premise of shimming the axles? Doing so will remove some of the in/out play, I understand that. I just don't understand the intent beyond removing some play.
lowblktaco is offline
Old 03-25-2009 | 07:45 PM
  #1620
mrramirez's Avatar
Thanks, I will try to pick up a losi aluminum arm soon. And maybe
better inserts.
