8IGHT 2.0!
#4852
collet by its self losa 9376
If you have to hold the crank from turning Imo you should use a crank locking tool like this one.crank locking tool
This is exactly why I do not use locktite on the flywheel nut. I've never had on come off. I just tighten it super tight while holding the flywheel like Doug mentioned. If you do locktite and have to lock the crank the worse thing you can do is put all that extra force on the rod. Again just my opinion.
#4853
This tool has helped tremendously when screwing on the clutch nut to get it good and tight with no loctite. Worth every penny.
http://www.amainhobbies.com/product_...ow-Plug-Wrench
#4854
that's the key to my flywheel success as well!
#4857
