Inferno MP9 thread
#7263
#7264
Racers Edge alloy twin-bolt for steering. But you're referring to the throttle scraping, aren't you? It's very difficult to find an alloy servo horn which won't scrape because of the way the stock plastic one is setup. But I have seen one brand that would work perfect, but I can't remember the brand. Could have been a german brand, the servo horn was anodized red and I think they only sell red, could perhaps be robitronic, still not sure though. But definitely works as one end is raised quite a bit so that end could be used for brakes and it wouldn't scrape.
#7265
For those who run with the battery in the front....I bought the WC forward battery mod kit. As you can see from my sig., the wife won't let me put it together until Christmas
My question is will any 5-cell hump pack work? I have a dynamite 1600 mah and an Orion 1900mah pack, with the Orion pack being thicker..which way does the battery mount? I can't seem to find a pic...
#7267
No reason to waste your time looking for a alum servo horn for throttle, Just use the stock horn. I have been using the same horn for years...with no problems
#7268
Without posting a pic, it's hard to describe my question, but I'll try. My 2 battery packs are 1600 mah and 1900 mah. As expected, the 1900 mah is thicker when I lay it on it's side as compared to the 1600 mah. However, when I set them upright (with the 3 cells on the bottom, and 2 on the top) they are roughly the same size......so I guess what I am asking is which way does the battery mount? On it's side, or upright?
#7269
I concur and would have to agree. There isn't really all that much (if any) need for an alloy brake/throttle servo horn as there isn't anywhere near the forces or amount of torque going through it as compared with the steering servo's horn, definitely alloy there.
As all 4 wheels can be locked up quite easily using the plastic horn, any further application of torque/trying to move the servo horn further into it's travel is only going to cause damage to the servo gears and motor. Cody even won his WC title using the original Kyosho part and Tebo has won all his recent races and titles also with the stock plastic part.
Just out of curiosity, why did you want the alloy version, any specific reason or problem you're having?
#7271
#7273
hi guys, im about to get an mp9 but would like to ask are they going to introduce a newer model maybe this year or next year?
#7274
The mp9 has pretty much been the same geometry throughout all "models" , the mp9 (se), tki1,tki2,tki2 wc, there have been very minor changes and nothing that cant be purchased seperately to make your car your own
#7275
short answer to your question is yes .. not sure why all the discussion about the rear hub holes as it wasn't you original question.. am I right?
