Inferno MP9 thread
#6511
#6512
#6514
Great Job Coach, I was good to finally meet u in person. This is ken you helped me with my shocks on my car before my main started. Send me an e-mail with your info.
Thanks For the Great info on the MP9.
Ken
Ken
#6515
Does somebody know where to find the F/R diff outdrives?? Or can I get the 777 ones?????
#6517
Wow if anyone wants a mp9 tki2 bad enuf some on ebay for a stupid price of 1029.00 plus 17 to ship. Someone will buy it im sure great buggy but just cuz no one has any guess the want to steal the money.
#6518
had tested this weekend on regionalīs the outdrive mod by CoryD, Hongnor outdrives, and none problem with it, i advise you to test it...
using 91/93 shafts (f/r) but the best is using 91mm on all 4! and track width on medium at rear.
rcmad2700: a good setup to start it will be the cody king pattaya worlds! just so easy to drive this kyosho!!!
#6519
I think that may conflicks with the Byron Challenge
#6520
#6523
Here's is a setup that I ran @ Ty Tessmann's home track. He drove it and said it was a little to easy to drive for his taste, but I really liked it. It was a high bite clay track with a LOT of jumps.
http://www.tracksiderc.info/TSRCOnli...ascx&Setup=150
If it isn't aggressive enough for you stand the rear shock up a bit, and I think you could lay the front shock down one hole too. You will find this car doesn't have a lot of setup changes from track to track. Box stock works well too. I seldom do anything radical. The only time I've ever really changed it is on low-bite bumpy tracks.
Later,
Later,
#6524
#6525
http://www.tracksiderc.info/TSRCOnli...ascx&Setup=209
The orange rear springs helped it go through the bumps better, but it seemed to tighten the car up a lot (loss of steering). So I made the front a bit more aggressive with softer springs and a roll center change. I raised the front arms to lower the roll center. If this car has too much steering for your track, put the light blue springs back and/or put the roll center back to stock.
The setup is very easy to drive. Our track has quite a few rutts and this car just coasts through them.
Give it a whirl and let me know if it worked for you.
Regards,
Regards,
